speedo pinion gear #1740068
01/27/15 12:05 PM
01/27/15 12:05 PM
Owosso, Michigan
stateroadhog Offline OP
Owosso, Michigan
okay according to chart with 4.10 gears and BF goodrich 275-60-15 tires that are suppose to be 28 inches tall I need a 38 tooth gear. When I actually measure tire I get 27.5. Again according to chart a 27 inch tire would use a 40 tooth. So I guess my question is would I use a 39? Thanks
Re: speedo pinion gear [Re: stateroadhog] #1740069
01/27/15 12:57 PM
01/27/15 12:57 PM
scratchnfotraction Offline
when you type it in to the calculator in the archives it comes out 38.40 so a 38 gear is needed.
it shows tire size as 27.99
Re: speedo pinion gear [Re: scratchnfotraction] #1740070
01/27/15 01:09 PM
01/27/15 01:09 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Use a 38 and check it against a measured mile, chances are you will be very close, rim width can change tire hiegth to a degree.
Careful, your character's showing!
