318 mag. engine temp ?? #1739790
01/27/15 02:00 AM
01/27/15 02:00 AM
IL
BlwnCrcab Online content OP
BlwnCrcab  Online Content OP
IL
just did a motor swap in 98 1500 2wd. put a 96 motor in it
takes a long time to build up heat in motor,
wont go over 150deg. put a new 190deg.thermostat in it still wont heat up. trip to work barly hit 150 20 miles, out side temp 30deg.
old motor would get to 180deg. everything else works fine
thanks for any info carey
Re: 318 mag. engine temp ?? [Re: BlwnCrcab] #1739791
01/27/15 02:15 AM
01/27/15 02:15 AM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Are you going by the factory gauge or aftermarket?
How is the heater working? Same as old engine or weaker?
Re: 318 mag. engine temp ?? [Re: BlwnCrcab] #1739792
01/27/15 03:07 AM
01/27/15 03:07 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
sounds like thermostat is stuck open. got a digital infrared temp gun? check temps with gun at upper and lower hoses, and on top of manifold.
Re: 318 mag. engine temp ?? [Re: BlwnCrcab] #1739793
01/27/15 01:24 PM
01/27/15 01:24 PM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
I had same problem years ago. Mine was a faulty thermostat. It was the expensive stant thermostat. Went back to a low buck and problem solved.
Re: 318 mag. engine temp ?? [Re: sportfury70] #1739794
01/28/15 01:17 AM
01/28/15 01:17 AM
Tidewater, VA
TMCCuda Offline
TMCCuda  Offline
Tidewater, VA
I'm thinking out loud here, but IIRC Magnum Beer Barrel manifolds have the sending units in different positions depending on year. Also, I think there is a coolant temperature sensor (black 2 two spade conn.)and a separate coolant sending unit (grey 1 spade conn.) Make sure the connectors aren't switched around and that either one is not broken. They do break easily and they are cheap to replace.
Search RockAuto for pictures.
1970 Plymouth Barracuda 1994 Ram 1500 4x4 5.2L 2004 Ram 1500 4x4 5.7L Quad Cab
Re: 318 mag. engine temp ?? [Re: TMCCuda] #1739795
01/28/15 01:51 AM
01/28/15 01:51 AM
IL
IL
factory gauge, heat not as good as old engine
have not used heat laser on it yet
thermo is new could still be bad, nothing changed from old thermo to new one
I used the 98 intake whitch has only one sending unit in it 2 wires the 96 intake had 2 sending units
it is in my brothers truck he put cardboard in front if rad. today covering all of it. got to 180 and had more heat
will check it w heat gun tomorrow
Re: 318 mag. engine temp ?? [Re: BlwnCrcab] #1739796
01/28/15 02:13 AM
01/28/15 02:13 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I think your viscous is screwed. It's locked up and pulling air all the time.
Mo' Farts
Moderated by "tbagger".
Re: 318 mag. engine temp ?? [Re: Grizzly] #1739797
01/28/15 02:19 AM
01/28/15 02:19 AM
IL
IL
would that be fanclutch? that is from the 96
Re: 318 mag. engine temp ?? [Re: BlwnCrcab] #1739798
01/28/15 01:20 PM
01/28/15 01:20 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Yes, it is.
Do you have another fan off your old engine?
Mo' Farts
Re: 318 mag. engine temp ?? [Re: Grizzly] #1739799
01/28/15 09:00 PM
01/28/15 09:00 PM
IL
IL
yes I still have the fan
will try switching that this weekend
