318 duster sounds sluggish
#1739317
01/26/15 07:46 PM
01/26/15 07:46 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I'm just getting my 73 318 Duster ready for the road, i've fitted fresh plugs, timed the engine and had a vac gauge on it but it sounds very laboured. I haven't driven it yet so it might be better when i get it out and run it. The motor is stock other than a alloy intake and 600 holley V/S, it has cast manifolds and a single exhaust which looks around 2", could this be the cork in the bottle ? It also has air con, wow, i've never seen so much junk. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: 318 duster sounds sluggish
[Re: DAYCLONA]
#1739319
01/26/15 09:55 PM
01/26/15 09:55 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
Time to drop in a 440
Yep
[Re: forphorty]
#1739320
01/26/15 10:28 PM
01/26/15 10:28 PM
deaks
robin hood country
In case you hadn't noticed i already have one, the Duster is up for sale and i dont want the buyer to feel too dissapointed. My Dart in my sig was originally a 340 4 spd that ran high 12's in the mid 80's with a hyd cam and mildly ported X heads, so i know sb's can perform just not this one. Lol Are 73 318's really this bad ? Mick
[Re: deaks]
#1739321
01/26/15 11:18 PM
01/26/15 11:18 PM
Posts: 1,357 central Florida
VL21
central Florida
Just a suggestion, bump the timing up to where it sounds good to your ear, the later 318s used a different (?) timing method, maybe a dial back, and the timing marks usually don't gibe, at least in my experience. On the current 318 in my D150 the balancer mark is out of sight up under the water pump. Basically, set the timing with a vacuum gauge ... I think mine could stand even a little more advance.
It takes gasoline to interest me.
[Re: Ply72rr]
#1739323
01/27/15 01:13 PM
01/27/15 01:13 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
bump it ahead some...it sounds like it's late...
...FAFO...
[Re: skicker]
#1739324
01/27/15 02:08 PM
01/27/15 02:08 PM
deaks
robin hood country
I've noticed a lot of the guys who race small blocks only run around 32 degrees, i think i set this around 36 but it did sound better with more, i was just worried about detonation. Maybe i should plug the vac advance as well. It shows 20" of vacuum with a dial gauge. What comp is the 73, 8 to 1 ? Mick
[Re: VL21]
#1739325
01/27/15 03:12 PM
01/27/15 03:12 PM
Posts: 782 s.e. MI
partsforsale
s.e. MI
This.
