FHO Modified - Internal Oil Lines to Rockers #173781
12/24/08 12:50 AM
12/24/08 12:50 AM
WI.
Scotts71chall Offline OP
WI.
Anyone have a picture of this and what it is doing and who needs it?
Re: FHO Modified - Internal Oil Lines to Rockers [Re: Scotts71chall] #173782
12/24/08 12:59 AM
12/24/08 12:59 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Not sure what he is doing but here is my set up. Kind of hard to see but you can see the AN fitting in the main oil galley and the other to the rocker stand. BTW this is a World block.
Re: FHO Modified - Internal Oil Lines to Rockers [Re: Al_Alguire] #173783
12/24/08 01:51 AM
12/24/08 01:51 AM
WI.
WI.
Is there one on both sides?
Is the oil passage going up thru the block also being used?
My world block has a screw in restrictor in that passage, why not take that out?
Re: FHO Modified - Internal Oil Lines to Rockers [Re: Scotts71chall] #173784
12/24/08 02:00 AM
12/24/08 02:00 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes mine had one on each side. I did not use the stock type oiling through the deck, left it plugged. I also had spray bar oilers in the valve covers.
Re: FHO Modified - Internal Oil Lines to Rockers [Re: Al_Alguire] #173785
12/24/08 10:16 AM
12/24/08 10:16 AM
detroit area
moderncylinder Offline
detroit area
barton started doing that like 20 years ago
Re: FHO Modified - Internal Oil Lines to Rockers [Re: moderncylinder] #173786
12/24/08 11:06 AM
12/24/08 11:06 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The cross over line is mandarory if lifter oiling is restricted,or eliminated and through head oiling is retained.
Re: FHO Modified - Internal Oil Lines to Rockers [Re: moderncylinder] #173787
12/24/08 12:38 PM
12/24/08 12:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Those heads are from Barton. Some Stage V thing they had specifically made for them back in the 90's. They used goofball guides and valves. Had one heck of a time finding replacement parts for them.
