Restoring dash pad myself... #1737813
01/24/15 06:43 PM
01/24/15 06:43 PM
NorCal
fatsat Offline OP
fatsat  Offline OP
NorCal
Mine has a few cracks in it. Found some instructions on the subject...
http://www.urethanesupply.com/Repair-Cracked-Dashboard/
Any opinions or advice on doing something like this?
Re: Restoring dash pad myself... [Re: fatsat] #1737814
01/24/15 07:08 PM
01/24/15 07:08 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
What's the worst that can happen, right? Go for it.
If it don't work, oh well, send it out.
Thanks for the link, saved it.
Mo' Farts
Moderated by "tbagger".
Re: Restoring dash pad myself... [Re: Grizzly] #1737815
01/24/15 07:56 PM
01/24/15 07:56 PM
68gtx Offline
68gtx  Offline
I have used a very similar system. It is not as easy as they make it look. Think about how flat a body panel has to be. The dash pad will look good as long as your prep work is spot on.
Re: Restoring dash pad myself... [Re: 68gtx] #1737816
01/24/15 10:48 PM
01/24/15 10:48 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I would think fixing a hole would be MUCH simpler than fixing a crack. With the curling you get at the edges of a crack, I would like to see how this method would address that.
Re: Restoring dash pad myself... [Re: 6PakBee] #1737817
01/24/15 11:01 PM
01/24/15 11:01 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Back in the 80's I knew a guy who was on call at the dealer I worked at, he was amazing. He fixed a huge gash in the dash of my friends '73 Road Runner in less then 10 minutes flat.
Filled it, textured and paint matched it in 10 min or less. Was the most amazing bit of work I have ever seen and we could not find the repair. Mind you the pad was still IN THE CAR. I happened to stop by to pickup tools from my box and mentioned the dash to him.
"I think its got a hemi"
Re: Restoring dash pad myself... [Re: gdonovan] #1737818
01/25/15 12:00 AM
01/25/15 12:00 AM
68gtx Offline
68gtx  Offline
When the edges are curled up you cut the edges back until you have solid material to work with it. Someone that does this on a regular basis are like artist. Some systems are better than others.Find an old pad and practice some before you do yours.
Re: Restoring dash pad myself... [Re: fatsat] #1737819
01/25/15 01:00 AM
01/25/15 01:00 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'm reading this and thinking ... you have a textured pad BUT the fillers are sanded smooth. Then you spray a texture over that. Theoretically the end result will be a finer texture over the repair and a coarser texture over the original.
Re: Restoring dash pad myself... [Re: Stanton] #1737820
01/25/15 03:18 AM
01/25/15 03:18 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
That partly depends on how it's sprayed. Also, you can lightly sand the texture, which will remove the 'peaks' and the remaining material will appear coarser.
When I restored one of my Shelby Dakotas, the dash pad was cracked and I was unable to find a replacement. I had a guy come out and repair it. He did a nice job, but it was not perfect. I could tell a bit of difference in the texture and his color match was off a bit.
I had some Dupont vinyl paint mixed at the parts store and resprayed it myself. It made a major improvement.
The pic below is of the repaired dash pad. It had cracks in the corners of the 'tray' area below the tag and some big splits across the top.
Note the texture of this pad, and I will next post an original.
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: Restoring dash pad myself... [Re: MOBodyman] #1737821
01/25/15 03:23 AM
01/25/15 03:23 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
Here is a pic of an original pad. You can see the difference in the texture of the vinyl. I believe a light sanding would have made the repaired dash look more original but it still wouldn't look like this one.
Also, the pads look entirely different colors in the pics but the Dupont vinyl paint used on the dash in the first pic was a dead on match. The little vent to the right wasn't painted. The first pic may have been taken with a flash.
Dallas
Re: Restoring dash pad myself... [Re: MOBodyman] #1737822
01/25/15 11:44 PM
01/25/15 11:44 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think if both photos were taken under the same lighting conditions they'd appear to be a better match. The flash is eliminating any shadows so there appears to be very little texture. Nice job though. Too bad someone doesn't make a vinyl seat repair product that works as good !!
