Electrical question #173661
12/23/08 09:45 PM
12/23/08 09:45 PM
Mount Airy, Maryland
scrag Offline OP
scrag  Offline OP
I noticed that my Headlights dim and brighten (as does the dash light) when my blinkers are on? I figured that someone else has seen this before and might point me in the right direction.
Car is 1970 Plymouth Cuda.
Re: Electrical question [Re: scrag] #173662
12/23/08 09:54 PM
12/23/08 09:54 PM
Kirkland, Washington
Pacnorthcuda Offline
your battery may be nearing the end and/or your charging system is weak.
Guessing your only noticing this as your car is idling at a stop right?
Re: Electrical question [Re: Pacnorthcuda] #173663
12/23/08 10:28 PM
12/23/08 10:28 PM
Houston, Texas
FastOrange Offline
FastOrange  Offline
Houston, Texas
check out this sight for a ton of info on upgrading your old electrical system.
www.madelectrical.com
Re: Electrical question [Re: FastOrange] #173664
12/23/08 10:57 PM
12/23/08 10:57 PM
You might clean EVERY electrical connection & consider upgrading to a dual field mid/late 70's squareback alt. adding an auxilliary 8 gauge lead from the alt batt stud to the starter relay batt stud is a good idea(w a #12 fusible link inline) & Nacho's plan of just running 2 leads in/out from the ammeter through the firewall bypassing the bulkhead is a good idea & as said Mad's info is excellent.
Re: Electrical question [Re: scrag] #173665
12/24/08 01:33 PM
12/24/08 01:33 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Rig up a light bulb socket and bulb with leads long enough to use as a tester. Use the device to follow the problem back towards the battery or from the battery towards the problem. If the problem shows at the battery you need a battery or have a charging problem.
Re: Electrical question [Re: Lefty] #173666
12/24/08 06:07 PM
12/24/08 06:07 PM
Tampa Florida
MoparTod Offline
MoparTod  Offline
Tampa Florida
Throw a volt meter on the alternator. Put the red lead on the big post of the alternator and black lead on the case of the alternator. Record the voltage. Now go to the battery and do the same thing. If you have more than a .50 volt difference you may have some resistance issues. Check your ground cable for high resistance. Check the connection and verify it is clean. Yoy should see at least 13.6volt for a good charging alt. I dont know how to full field this application but if you can find out the alt will put out its max. voltage during this test. There are specs im sure you can compare it with. You might just have a bad regulator also. They are only 20.00. Hope this helps. Tod
Re: Electrical question [Re: MoparTod] #173667
12/25/08 06:57 PM
12/25/08 06:57 PM
scrag Offline OP
scrag  Offline OP
Thanks everyone.
Re: Electrical question [Re: scrag] #173668
12/26/08 10:42 PM
12/26/08 10:42 PM
scrag Offline OP
scrag  Offline OP
I have the following:
Engine running - 13.6 at battery, 14.3 at the alternator.
Engine Off - 12.6 volts from the battery.
Re: Electrical question [Re: scrag] #173669
12/26/08 10:50 PM
12/26/08 10:50 PM
.7 volt drop from alt "batt" terminal to battery positive post is too much. I'd clean all connections starting with the bulkhead
Re: Electrical question [Re: RapidRobert] #173670
12/26/08 10:54 PM
12/26/08 10:54 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have .09 with 6ga wire straight to the battery and a 100a breaker.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
