68 GTX Woodgrain Inserts ? #1735697
01/21/15 04:49 PM
01/21/15 04:49 PM
68gtx Offline OP
68gtx  Offline OP
What actually holds the inserts in place? It looks like just the stainless corner trim? The dash was some what apart when a got it. Also does the corner trim just screw into the A pillar trim? Any detailed pictures of a 68 GTX dash would be great. Thanks Larry J
Re: 68 GTX Woodgrain Inserts ? [Re: 68gtx] #1735698
01/22/15 01:43 AM
01/22/15 01:43 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
There is a little, tiny "T nut" that attaches to the small cutout on the dogleg. Problem is, most people bust that section when removing the piece. I've passed up many a used piece that was otherwise very nice due to this issue.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: 68 GTX Woodgrain Inserts ? [Re: 5wndwcpe] #1735699
01/22/15 03:28 AM
01/22/15 03:28 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
....What he said. And yes...the screw goes into the moulding. Kinda bizzare....but it works.
I may have some spare T-nuts . I could look if you want...
Re: 68 GTX Woodgrain Inserts ? [Re: superwrench] #1735700
01/22/15 09:53 AM
01/22/15 09:53 AM
68gtx Offline OP
68gtx  Offline OP
I see no t-nut on the dog leg? Anyone have picture? Superwrench if you have some spares i would be happy to purchase them. Thanks Larry J
Re: 68 GTX Woodgrain Inserts ? [Re: 68gtx] #1735701
01/23/15 11:22 AM
01/23/15 11:22 AM
68gtx Offline OP
68gtx  Offline OP
I have set from ebay that are ok. Anyone ever had these restored.I heard 750$ is the going rate seems like a lot $$. Originals are hard to come by.Anyone else doing them besides Instrument specialties. They did my gauge cluster which is awesome.:) Thanks Larry J
Re: 68 GTX Woodgrain Inserts ? [Re: 68gtx] #1735702
01/24/15 12:29 AM
01/24/15 12:29 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Mike is the only one doing them that I know of. The face is not nearly as important as the back. You can always polish out the scratches or sand it with 800 and clear over it.
Keep in mind '68 and '69 are different and most people don't know which they have when they advertise them.
The radio bezel is easier as the '69 has writing and the '68 does not.
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
Re: 68 GTX Woodgrain Inserts ? [Re: 5wndwcpe] #1735703
01/24/15 11:56 AM
01/24/15 11:56 AM
68gtx Offline OP
68gtx  Offline OP
I know the 68's are lighter than 69. Mine are 69's not 68 for sure. These are not easily found. I purchased as set from a vendor on Ebay. They look OK. He just does an overlay on top. Again they look OK but not done like the originals. If anyone has a set from a 68 GTX they what to part with let me know. Thanks Larry J
Re: 68 GTX Woodgrain Inserts ? [Re: 68gtx] #1735704
01/25/15 05:58 PM
01/25/15 05:58 PM
68gtx Offline OP
68gtx  Offline OP
Anyone have a picture of how these attach? Thanks Larry J
Re: 68 GTX Woodgrain Inserts ? [Re: 68gtx] #1735705
01/30/15 09:05 PM
01/30/15 09:05 PM
68gtx Offline OP
68gtx  Offline OP
Still looking for any pictures of how these attach to the dash? Thanks Larry J
Re: 68 GTX Woodgrain Inserts ? [Re: 68gtx] #1735706
01/30/15 09:46 PM
01/30/15 09:46 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Here's my Sport Satellite, with the upper trim removed.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: 68 GTX Woodgrain Inserts ? [Re: herkamer] #1735707
01/30/15 09:47 PM
01/30/15 09:47 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
2nd pic. The small Phillips screws are what holds it to the dash frame. This one is missing the screw up top.
Matt
69 Dart Swinger 340
and even more
Re: 68 GTX Woodgrain Inserts ? [Re: herkamer] #1735708
01/31/15 12:38 AM
01/31/15 12:38 AM
68gtx Offline OP
68gtx  Offline OP
Thanks so much for the pictures.
Re: 68 GTX Woodgrain Inserts ? [Re: 68gtx] #1735709
01/31/15 12:37 PM
01/31/15 12:37 PM
68gtx Offline OP
68gtx  Offline OP
Has anyone tried to polish the fine scratches out of these inserts? If so what did you use and what level of success did you have? Mine have some very fine scratches I would like to try and remove. Thanks Larry J
Re: 68 GTX Woodgrain Inserts ? [Re: herkamer] #1735710
01/31/15 02:44 PM
01/31/15 02:44 PM
superwrench Offline
superwrench  Offline
....You can see the little flat-headed T style mounting clip on the lower right of that Sport Satellite insert....I'm sure the left side has one as well.
Re: 68 GTX Woodgrain Inserts ? [Re: superwrench] #1735711
02/04/15 01:06 PM
02/04/15 01:06 PM
68gtx Offline OP
68gtx  Offline OP
Looking for the fastener ( T-nut ) that holds the right lower part of the hockey stick. Anyone know where to find these? Thanks Larry J
Re: 68 GTX Woodgrain Inserts ? [Re: 68gtx] #1735712
02/04/15 02:12 PM
02/04/15 02:12 PM
superwrench Offline
superwrench  Offline
Larry...I sent you a PM a few days ago...
Re: 68 GTX Woodgrain Inserts ? [Re: superwrench] #1735713
02/04/15 04:31 PM
02/04/15 04:31 PM
68gtx Offline OP
68gtx  Offline OP
Superwrench you have PM sorry I have not checked mine in a while. Thanks Larry J
