Re: After market power brake question. Brakes locking.
[Re: Andrewh]
#1733996
01/19/15 04:08 PM
01/19/15 04:08 PM
Posts: 2,968 Far Northeast.
mymcodebee
Far Northeast.
I think it is typically of either a bad booster, or your pedal doesn't go back far enough. which would be why the guy put in shims.
There is a valve internal to the booster that "breaks" when you hit a certain point. It is supposed to be gradual but on one of mine, it gave away suddenly and would jerk the brakes. if you cannot let up enough to close it, the brakes won't disengage.
Try disconnecting the pedal and see if you pull back a little further, if you can't get it to release.
Also, you might unbolt the brake light switch, which is probably stopping it from moving back further instead of unbolting the pedal. you might be able to adjust it to allow further movement.
Ahhh. I think you nailed it. I had to bend the brake light switch a bit in order for the brake lights to work and I bet it is holding up the pedal. I will check those ideas when I get in the garage tonight. Thanks for the tip.
[Re: mymcodebee]
#1733997
01/19/15 05:46 PM
01/19/15 05:46 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The front reservoir feeds the rear brakes.
Where is your line lock plumbed?
The front reservoir, which usually means it blocks brake pressure to the rear when on. You may want to make sure the line lock isn't acting like a one way valve.
[Re: Supercuda]
#1734000
01/21/15 01:09 PM
01/21/15 01:09 PM
mymcodebee
Far Northeast.
It appears to be hooked to the larger front reservoir of the master. You can see it just above the master in the pic attached.
yes it does, but then again it also appears it is possible to put the cover on backwards and it might not be so. That is why I really dislike aftermarket kits, they are usually a hodgepodge of stuff that is a bear to fix when there are issues.
Good point. I will check.
