Cummins Fuel Filter Replacement #1733854
01/19/15 10:56 AM
01/19/15 10:56 AM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
I suspect that I need to replace the fuel filter on my '05 Ram & would like to know the procedure. When I still farmed, some of our diesel equipment required nothing when doing a change while some of them you had to open a bleed screw & manually pump the air out. There's no info in the owner's manual other than the part number. I'm guessing this doesn't require anything special but before I mess with it I would like to hear from someone with experience. Thanks.
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin www.wwnboa.org if you're interested in '62-'74 B-Bodies
Re: Cummins Fuel Filter Replacement [Re: GTX4spd] #1733855
01/19/15 11:08 AM
01/19/15 11:08 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I've never had to do it myself but I know when they change mine they cycle the ignition switch 3 or 4 times after its back together to prime it before they start it. Usually one guy checks for leaks while another cycle's it.
...FAFO...
Re: Cummins Fuel Filter Replacement [Re: skicker] #1733856
01/19/15 11:43 AM
01/19/15 11:43 AM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
Thanks for that info, anyone else?
Re: Cummins Fuel Filter Replacement [Re: GTX4spd] #1733857
01/19/15 12:12 PM
01/19/15 12:12 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Go to cumminsforums.com and check out a previous section called 3rd gen popular fuel filter data. There are some filter brands to stay away from as they don't do a very good job. You must keep that system clean or you are going to be spending 3k plus for injectors.
Carl Kessel
Re: Cummins Fuel Filter Replacement [Re: GTX4spd] #1733858
01/19/15 01:31 PM
01/19/15 01:31 PM
Detroit, MI
RPM Motorsports Offline
Detroit, MI
nothing special on my 03. unscrew the lid. out w/ the old and in with the new. put the new o-ring on and re-install the lid. start truck and check for leaks.
Re: Cummins Fuel Filter Replacement [Re: RPM Motorsports] #1733859
01/19/15 02:14 PM
01/19/15 02:14 PM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
Thanks all
Re: Cummins Fuel Filter Replacement [Re: GTX4spd] #1733860
01/19/15 02:52 PM
01/19/15 02:52 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Lots of videos on the internet....
http://www.youtube.com/watch?v=-HNfa6vV1yk
Easy job, take your time if it's your first time.
Hardest part is collecting the diesel fuel you drain out of the filter housing, not much fuel is lost.
Be careful when re-installing the plastic lid, it has fine threads that can cross-thread easily damaging the fragile plastic threads.
Make sure the lid is flat on the housing and start tightening the lid very slowly by hand and make sure it's going on correctly.
Make sure you close the drain valve on the filter housing when your finished and BEFORE trying to start your truck.
When restarting your truck I cycle the key forward a few times, you can hear the fuel pump running.
After cycling it my truck usually starts right up and runs for about 30 seconds then stalls.
I cycle the ignition a few more times and then turn the truck over.
Usually takes about a minute of turning the truck over and releasing until the truck starts for good.
Re: Cummins Fuel Filter Replacement [Re: KillerBee] #1733861
01/20/15 12:23 PM
01/20/15 12:23 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
One more thing on the filter change. Even though it looks like you could stick in a 3/8 drive ratchet into the lid, DON'T! You will break the lid at that area. Use only a wrench or socket on the outside hex to unscrew the lid. 1 1/8 if I remember correctly.
Carl Kessel
Re: Cummins Fuel Filter Replacement [Re: KillerBee] #1733862
01/20/15 02:12 PM
01/20/15 02:12 PM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
The mechanics of changing it are no big deal, I've worked with farm equipment all my life. Our last combine had the fuel filter & water separator located on the right side of the transverse-mounted block, out of sight, out of reach. You had to lean over the engine, peering upside down with a shop light to get to them. Not as simple as it may sound.
It was just the priming that I was concerned with, since, as stated in my first post, some of our equipment needed extra work to get the air out.
But the Cumminsforums.com site was a nice revelation, don't know why I hadn't thought to search for something like that! Seeing the unanimous acclaim for the Baldwin filter convinced me to go that route instead of NAPA or the factory filter from the dealer. Bad part is I had to order it & now gotta wait, no place local carries 'em.
But I appreciate everyone here who weighed in, always can find good info here.
Re: Cummins Fuel Filter Replacement [Re: GTX4spd] #1733863
01/21/15 01:54 AM
01/21/15 01:54 AM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
I know the Baldwin and Wix filters are the same( just had both of them in my hands Last Friday) and I believe the Napa(gold) filter is the same too but have not had one in my hand to compare yet.. I had the Baldwin filter because a guy I worked with had bought a couple and sold his truck before he used the second one, I bought the Wix because I forgot I had the Baldwin.. Apparently someone had bought the Wix took the O-ring and returned the filter and then I recieved it with out an O-ring.. I went and got another wix and found the baldwin when I got back to my shop, I was curiose what the difference was so I pulled them both out and compared them , they were identical.. I put the baldwin in because it was older( not saying they break down with age but I always use the older supplies before the new stuff)..
Re: Cummins Fuel Filter Replacement [Re: rumblebee4232] #1733864
01/21/15 08:44 PM
01/21/15 08:44 PM
Garry Owen Offline
Garry Owen  Offline
Baldwin pf7977
Re: Cummins Fuel Filter Replacement [Re: Garry Owen] #1733865
01/21/15 10:47 PM
01/21/15 10:47 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
If you are going to run a Wix, Get the 33585XE instead of the plain old 33585. They are a 5 micron filter instead of 7. Your injectors will thank you. Better yet, an aftermarket 2 micron filter setup is worth the money on a common rail. They will NOT put up with dirty fuel. Run cheap filters with todays trash fuel and you WILL have problems. They are nothing like your 60s model John Deere tractor that runs fine on fuel pumped out of some old rusty tank.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Cummins Fuel Filter Replacement [Re: 71yelladustr] #1733866
01/30/15 02:13 PM
01/30/15 02:13 PM
Northern IL
meathead66 Offline
meathead66  Offline
Northern IL
FYI the Wix 33585 XE is available at O'Reilly's for $23.99.
