Back in the Day #1732393
01/17/15 08:52 PM
01/17/15 08:52 PM
Rio Linda, CA
John_Kunkel Offline OP
Rio Linda, CA
If one could go back to, say, 1968 and build a B Gas car with todays knowledge and using yesterday's parts, would Hilborn injection outrun a sheet metal tunnel ram all else being equal?
Re: Back in the Day [Re: John_Kunkel] #1732394
01/17/15 11:47 PM
01/17/15 11:47 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I would say yes.
Kevin
Re: Back in the Day [Re: Twostick] #1732395
01/18/15 11:36 AM
01/18/15 11:36 AM
gregsdart Offline
gregsdart  Offline
Once tuned, it should. It will be tough to get the fuel curve right. The fuel curve from the injector pump before any high speed leanouts is linear, and the fuel demand is far from it on most engines. Gas having only a three percent tuning window, you can see how that would be a problem. On top of that, idle has to be pig rich on a constant flow system because there are no accelerator pumps. I don't know how quickly plugs fouled running gas , but I would bet it was quick.
If I were going to try that, I would book some dyno time to set up three staged bypasses, or have a data logger.
Re: Back in the Day [Re: gregsdart] #1732396
01/18/15 02:31 PM
01/18/15 02:31 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I thought the altereds in the 70's ET'd better with a cast TR and carbs than they did injected?
Sheldon
Re: Back in the Day [Re: John_Kunkel] #1732397
01/18/15 11:45 PM
01/18/15 11:45 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
If your sole change was ONLY the manifold, I'd say the F.I. would still beat it. Why? Simple--you'd still have better throttle response, the F.I runners would still be optimal for the combo & the fuel delivery system wouldn't have changed. The only thing you're gaining with a sheetmetal intake is weight saving, perhaps better runner length but you're running the same old carbs. Now if you're talking a whole new intake system--intake AND carb change--- I'd still give the nod to F.I. but not by as wide a margin.....
