Re: Positive vs. negative piston deck height [Re: Plumcrazyracing] #173201
12/26/08 10:02 AM
12/26/08 10:02 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
it is worth pondering the
"crevice volume"
effect
crevice volume is generally thought to be a bad thing
because it 'quenches' the flame and creates unburned hydrocarbons ... which reduces both power and fuel economy
there is crevice volume in the little gaps of the head gasket joint
there is crevice volume in the 'ring land' from the top of the first ring to the piston crown
could the undesired two crevice volumes
be combined
to eliminate a bit of both?
some engine builders try to do this
by having the piston come above the deck
enough to cover the head gasket joint
during the peak of the combustion event
it is an approach that might gain a bit of
in one of the last 'Engine Masters' competitions one of the top engines had a very large value for positive deck and this may have been one of his strategies
there is also a small effect in being able to use a tiny bit longer connecting rod
it is worth thinking about
another small detail
"The Devil is in the Details"
Re: Positive vs. negative piston deck height [Re: mopacltd] #173202
12/27/08 11:00 PM
12/27/08 11:00 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I have read that a .055 piston to head clearance is the minimum you should have. Is this not true?
maybe with aluminum rods...but with tradtional rods, ~.040 is ideal, if you're very precise on measurements and keep the RPM's down you may be able to go as tight at .030"
2017 Grand Cherokee Overland
Re: Positive vs. negative piston deck height [Re: patrick] #173203
12/28/08 12:29 AM
12/28/08 12:29 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Alot of good points,most don't add up to 2 hp,but good points. Most post what they read or internet info.Keep it safe and don't try to get it too tight.
Re: Positive vs. negative piston deck height [Re: 360view] #173204
12/28/08 01:39 AM
12/28/08 01:39 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
"crevice volume"
effect
be combined
I like that idea as you described it.mike
Re: Positive vs. negative piston deck height [Re: Sport440] #173205
12/30/08 12:23 PM
12/30/08 12:23 PM
USA
3
360view Offline
360view  Offline
3
USA
an article on crevice volume
http://www.gofastnews.com/board/technica...ower-thief.html
for the hard core engine nuts
Re: Positive vs. negative piston deck height [Re: 360view] #173206
12/30/08 01:26 PM
12/30/08 01:26 PM
organ
maximum entropy Offline
organ
good article-thanks!
Re: Positive vs. negative piston deck height [Re: 360view] #173207
12/30/08 11:12 PM
12/30/08 11:12 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Thanks, Ive never seen a article from David Vizard that I couldnt make good logical sense out of.
mike
