Re: '74 W200 Pickup, Driver Door Sticks? Common Prob?
[Re: D_C]
#1730800
01/15/15 06:32 PM
01/15/15 06:32 PM
Posts: 6,024 Morningside
AdventurerSport
waaaay out there in left field
Morningside
Replace the door hinge/bushings, they are worn out and causing the door to drop. Easier than it looks, get the repair kit at any parts store and they will tell you how to do this easy repair.
Good luck!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
[Re: D_C]
#1730806
01/21/15 08:56 PM
01/21/15 08:56 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
I visited my truck the other day (unfortunately, it is not at home) and checked the hinges. Seems to me, that there is relatively little movement from the hinges. They may not be the problem I thought they were, at least with regard to the door not opening properly.
Instead, IS that the outer door handle button is not causing the latch to release without help. As suggested, the release rod needs to be adjusted with an Allen Wrench.
To test, I opened the door, then closed the latch mechanism by hand/with my fingers. When I tried to release the latch with the Button, pushing all the way in it would not release/open.
There is an ID plate riveted to the inner door from the Utility Box company (truck originally had a utility box bed) that covers the adjustment access hole. I will drill out the rivets, pull the plate and make the rod adjustment.
Thanks for all the replies, particularly from Jim (Demon) for the heads up on the button adjustment.
