Best and worst suspension parts. Update #1729506
01/14/15 12:50 AM
01/14/15 12:50 AM
Cab_Burge Offline OP
I'm putting a 1966 Dodge Coronet Deluxe two door sedan together for street use,(former six cylinder 3 speed car) 440 pump gas motor with a NP833 O.D. tranny with a Dana 60 rear with 3.54 gears and Mopar road racing replacement rear leaf springs. Nothing serious for at the track racing I'm a drag racer and I want this car to handle well on the street and for the parts to last a long time. My question is for the front suspension parts and rebuild kits, which brand parts are the best and who's the worst I used a "Just Suspension" Poly kit in my last street car, the idler arm didn't last 3,000 miles I found Moog, AC Delco and other brands that I don't know ,so who is good now and who is not
Thanks in advance for any help
Re: Best and worst suspension parts [Re: Cab_Burge] #1729507
01/14/15 01:00 AM
01/14/15 01:00 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Firm Feel can get you exactly what you need and sell you stuff that is NOT junk.
Mopar to the bone!!!
Re: Best and worst suspension parts [Re: 72Swinger] #1729508
01/14/15 01:11 AM
01/14/15 01:11 AM
IN
ahy Offline
ahy  Offline
IN
Last kit I got was from FF, along with some other goodies. Wear parts were Moog and have held up well. Also competitively priced as a package. Not sure what they are using now - probably Moog - but I would work with them again.
Re: Best and worst suspension parts [Re: Cab_Burge] #1729509
01/14/15 01:29 AM
01/14/15 01:29 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
My last look into this was Moog still was decent brand. At the time I recall folks spoke well of Morris_Quay (sp?), but I have no experience with them myself.
In fact right now, my recollection is that every ball joint and tie rod end on my car is Moog. Idler probably is too. Had used some TRW at one time. Like you, I bought a kit that had some real junk mixed in with the decent stuff. Either "Mr Suspension" or PST - I bought from both when I started on the car. I thin they were both actually Kanter operations. "Mr Suspension" almost certainly was. I remember greasing the inner tie rod ends and the grease came out in circle around the seam. Those tie rod ends saw zero miles!
Re: Best and worst suspension parts [Re: Mattax] #1729510
01/14/15 02:07 AM
01/14/15 02:07 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have a Spicer idler arm, replaced a TRW that was shot in probably 1000 miles of ONLY street driving.
Re: Best and worst suspension parts [Re: Cab_Burge] #1729511
01/14/15 02:26 AM
01/14/15 02:26 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I run the Moog stuff also. I even paid double for a K783 lower ball joint at NAPA auto parts
that wasn't available at the time anywhere else.
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Best and worst suspension parts [Re: RylisPro] #1729512
01/14/15 09:17 AM
01/14/15 09:17 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Put me on the list for buying one of those garbage kits. I forget if it was just suspension or pst. 2,000 miles and the ball joints were rattling more than the parts I replaced. Since then I've been using moog with good results.
Re: Best and worst suspension parts [Re: JAMESDART] #1729513
01/15/15 01:13 AM
01/15/15 01:13 AM
NY NY
3
340duster340 Offline
NY NY
i use moog with good results.
i also started saving good front end components from parts cars, because well i am cheap, and i know the used parts are still tight and probably better than most of the junk you can get now a days.
Re: Best and worst suspension parts [Re: 340duster340] #1729514
01/21/15 01:14 AM
01/21/15 01:14 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I went with Spicer, but have to wait until its on the road before I can truly test it. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Best and worst suspension parts. Update [Re: astjp2] #1729515
01/24/15 01:50 AM
01/24/15 01:50 AM
Thanks to all of you for the help on making the proper choice on which brand to buy I ended up ordering all Moog parts, ball joints, idler arm, upper and lower bushings and the special offset upper A arm bushings to improve the caster. I have not yet decided on what to do about the lower conrol arm struts yet, what do you guys recommend? Stock or better ones? Thanks again in advance
Re: Best and worst suspension parts. Update [Re: Cab_Burge] #1729516
01/24/15 04:36 AM
01/24/15 04:36 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
the moog improved design strut rod bushings are good and are not much more than the standard bushings. Rock auto has them listed for ~40 bucks
Re: Best and worst suspension parts. Update [Re: ntstlgl1970] #1729517
01/24/15 12:53 PM
01/24/15 12:53 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
According to a recently retired moog engineer "if it does not say made in america on the box its junk". They were bought and the new people running the show are bean counters. The engineers used to run the show for decades and now he could't believe the decisions being made. That was a big part of why he opted out.
Damon
Re: Best and worst suspension parts. Update [Re: mopardamo] #1729518
01/26/15 10:28 PM
01/26/15 10:28 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I went and bought some Moog ball joints because of this thread
still Made in USA
I don't need them but its good to have spares
I went and checked my upper ball joints on my Hotchkis A arms as I don't ever remember seeing this "Moog problem solver" mark on the top.
I doubt even the Hotchkis Mopar upper A arm ball joints are Moog
Better stock up fellas
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Best and worst suspension parts. Update [Re: RylisPro] #1729519
01/27/15 12:32 AM
01/27/15 12:32 AM
Santa Fe Springs, CA
Dan@Hotchkis Offline
We used to use Moog until we started having consistency/longevity issues. We've moved on to a more consistent/higher quality manufacturer now.
http://proforged.com/
Re: Best and worst suspension parts. Update [Re: Dan@Hotchkis] #1729520
01/27/15 01:01 AM
01/27/15 01:01 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Were these issues with the "Made in USA" parts? I am thinking maybe I got some Moog parts that were old stock or sitting on the shelf for a while. I did get them from Summit though so probably not?
I've read the Proforged stuff is made in Taiwan
http://www.chevelles.com/forums/showthread.php?t=397013#/forumsite/20668/topics/397013?page=2
I'm sure its good as its what is currently my upper ball joints but, I used to date a girl from Taiwan. She was neither consistent nor high quality.
Personally, I'll stick to the US stuff
haha!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Best and worst suspension parts. Update [Re: RylisPro] #1729521
01/27/15 01:18 AM
01/27/15 01:18 AM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
According to that post it says that the Moog stuff is "assembled" in USA or Mexico, not actually manufactured here, and I'm not sure where they source their materials and machining from?
The next step up would be Howe stuff, but that would bump the cost of a set of upper control arms 100-120 bucks?
Re: Best and worst suspension parts. Update [Re: 68rrunner] #1729522
01/27/15 01:45 AM
01/27/15 01:45 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I've seen the Howe stuff and it looks good
Pricey though at $74 for the regular upper ball joint and $84 for the extreme duty
https://www.howeracing.com/p-7921-howe-22320-fits-k772.aspx
Just not sure if they have a lower ball joint though?
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Best and worst suspension parts. Update [Re: RylisPro] #1729523
01/27/15 02:09 AM
01/27/15 02:09 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Wonder if my wheels could clear a +.3 or +.4?
Re: Best and worst suspension parts. Update [Re: Dan@Hotchkis] #1729524
01/27/15 01:30 PM
01/27/15 01:30 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I agree, Moog is mostly junk these days.
Re: Best and worst suspension parts. Update [Re: BergmanAutoCraft] #1729525
01/27/15 03:35 PM
01/27/15 03:35 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
MOOG (recently purchased by Federal-Mogul in the late 1990s) has its reputation as the dominant aftermarket supplier.. and highest quality, in particular with their "Made in USA" products. In fact, MOOG still supplies nearly 100% of the NASCAR parts... there IS a difference and MOOG has the advantage.
TRW has been the dominant OE domestic supplier for the big-3 car/truck mfgrs... Look for TRW parts with "Made in USA" on their cartons. You can't go wrong with either MOOG or TRW with "Made in USA" products.
Others??? Good luck and at your own risk.... very simply, you pay for what you get.
