Re: 1966/67 B body versus 1968/70 B body ?
[Re: Cab_Burge]
#1729433
01/13/15 10:41 PM
01/13/15 10:41 PM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
Cab , had the same question . Answer is to use the correct idler to match the k frame . No other issues . I will be doing this in a 64 or 65
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#1729434
01/14/15 03:56 AM
01/14/15 03:56 AM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
use the later k and corresponding idler then use 11/16 tie rods and adjuster sleeves from a c body.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: tex013]
#1729436
01/14/15 03:44 PM
01/14/15 03:44 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Tex
just get the 68-70 idler and everything else swaps over.
