Which Hemi Head?
#1725460
01/09/15 01:11 PM
01/09/15 01:11 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
I need heads for a 572 Roller Cam pump gas hemi and am looking at Stage V, Indy, and Edelbrock. Hughes Engines are claiming 446 CFM on their prepped Edelbrock head ( Hughes Link ) for $2800. Looking for feedback and experiences with all options and price paid if you have it. Thanks!!!
Re: Which Hemi Head?
[Re: mickm]
#1725463
01/09/15 04:37 PM
01/09/15 04:37 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Right now the Edelbrocks are the most bang for the buck. Indy has a similar product (their Hi-Po's) but...that's Indy. Stage V is my favorite but more bucks by the time you have someone complete them. Edelbrocks flow good, are ready to bolt on and cheaper than you could buy complete aluminum hemi heads at that flow rating 40 years ago. God I love it.
2011 Drag Pak Challenger
[Re: rickseeman]
#1725464
01/09/15 05:21 PM
01/09/15 05:21 PM
Posts: 4,179 California
mickm
California
yes, they do look good for the price. they do have the edelbrock logo on them, so as long as that isn't an issue.
and whoever designed their logo needs to take a quick look at an elephant. it looks like a cross between an elephant and a cow!
[Re: rowin4]
#1725467
01/09/15 06:41 PM
01/09/15 06:41 PM
mickm
California
I have Stage V prepped by Tim at FHO. for my 572. Cheaper and Hemi don't work together.
i agree, but i don't know that the edelbrock heads fall into the category of cheaper, meaning quality. innocent until proven guilty, i have to assume they will be of the quality of the rest of the heads they make, and so would work fine for the intended application.
i, on the other hand, won't be one to find that out personally!
[Re: mickm]
#1725468
01/09/15 09:58 PM
01/09/15 09:58 PM
Posts: 12,386 Taxes & Virus's R-US, NY
Dragula
Just ordered a set of Indy Hi-Po Hemi heads for my all aluminum 605...AKA Canfield heads with full port & polish $3400...Should flow 440-480 cfm....I will have them flowed locally so I know what they actually come in at...Indy bought out Canfield when they folded. My old 426-1 heads with me porting them went from 363 to 400cfm and there was more left in them, but the intake valve was the limiting factor. These new heads will have the 2.40 valves.... I have heard of issues bolting the eddy heads on and really didn't like the flow numbers I saw. The Stage V heads I got quotes for were double the price and did flow more, but mine is a street car, and you can go crazy $$$ with a Hemi if your not careful.... http://www.indyheads.com/images/31.cat2014.pdfhttp://www.indyheads.com/images/news1.2012.pdf
[Re: gsmopar]
#1725470
01/09/15 11:00 PM
01/09/15 11:00 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Stage V for my pump gas 572". Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Dragula]
#1725473
01/10/15 01:45 AM
01/10/15 01:45 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Randy; let me know what they actually flow. Are the valve angles stock or have they rotated the valves a bit?Dave
[Re: quickd100]
#1725477
01/10/15 01:49 PM
01/10/15 01:49 PM
Dragula
Dave,
It will probably be a month or so, I went thru BGR and not direct, so most of the parts should be on order, then I need to finish paying for it all and go get them...But yes, I will post flow numbers...He had a set there, and I liked them. They are far lighter than my 426-1 heads and will make the engine 1" narrower over the larger 426-1 heads. I will also be able to run T&D rockers if I so choose...
[Re: gsmopar]
#1725478
01/12/15 01:26 PM
01/12/15 01:26 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
From what I've seen so far, the Stage V is about 2k more than Edelbrock and flows about the same?Quote:
2K more? I just bought stage V's. Edelbrock castings are $1940 from Summit, Stage V castings were $2100.
Which ever way you ask about the steam holes in the deck. I think Edelbrock and Stage V come with them, I don't think Indy does. I don't think Indy blocks have the steam holes either. MP blocks do and KB does but they move them so they do not interfere with the sleeve flange. Stage V will put the holes in the right spot for a KB block if you tell them when ordered.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: d7cook]
#1725479
01/12/15 02:08 PM
01/12/15 02:08 PM
Posts: 503 Idaho
1320Dart
Idaho
The trick is to get Stage V to answer their phone.
Greg ----------------------------------------------------------------- Cost is irrelevant, making memories is far more valuable!
