Re: 2600-3000 stall converter... Which brand? [Re: Lmopar69] #1722892
01/08/15 09:43 PM
01/08/15 09:43 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'm happy with my custom built Ultimate converter, but it was expensive. My old Hughes converter was good also. I don't know your combination, but the truck looks cool. Call some of these companies mentioned and see what they recommend. I used a few "off the shelf" hi-stall converters that were OK, but usually a bit loose for street driving. The "custom" 9" converter Lenny at Ultimate built was exactly what I was looking for for my street/strip car. Flash stall to 5,000 RPM, but so tight on the street you can't tell it is a high stall converter.
Re: 2600-3000 stall converter... Which brand? [Re: 451Mopar] #1722893
01/09/15 12:21 AM
01/09/15 12:21 AM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Yeah, after talking to him, his converters sound like just what I'm after. He said it would be a 3000-3500 in a 9.5" converter. But I just can't make myself spend that kind of money on it right now.
I'm not trying to be "cheap", but I'm not going all out either. The is pretty much just a "look cool, go fast" toy for me anyway.
Laine
Re: 2600-3000 stall converter... Which brand? [Re: Lmopar69] #1722894
01/09/15 01:19 AM
01/09/15 01:19 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
JMO,
In an auto car, it's hard to find a component as singularly important as the torque converter.
Guys spend thousands on engines and upgrade, then try to run a $200 converter. No surprise when or why it runs like a gimpy dog.
Re: 2600-3000 stall converter... Which brand? [Re: Lmopar69] #1722895
01/09/15 11:43 AM
01/09/15 11:43 AM
Nebraska
70VcodeCoronetRT Offline
Nebraska
Nobody like Dynamic anymore?
Re: 2600-3000 stall converter... Which brand? [Re: 70VcodeCoronetRT] #1722896
01/09/15 12:37 PM
01/09/15 12:37 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Dynamic is closed until the 12th.
Re: 2600-3000 stall converter... Which brand? [Re: Lmopar69] #1722897
01/09/15 02:56 PM
01/09/15 02:56 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I have a PTC 9.5" that does exactly what Kenney said it would. He will ask all kind osf questions about you car and engine to get it right. I asked for 2500 stall for a street/strip car and I got exactly that.
Re: 2600-3000 stall converter... Which brand? [Re: babarracuda] #1722898
01/09/15 02:59 PM
01/09/15 02:59 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
I always wondered if a high stall lockup converter could give you the best of both worlds. Say around 3500, but in street mode, there's no reason it couldn't engage the clutch at 2000 rpm and stay locked up until you slow back down. Is there anything like that out there?
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: 2600-3000 stall converter... Which brand? [Re: 70VcodeCoronetRT] #1722899
01/09/15 07:55 PM
01/09/15 07:55 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I like my Dynamic.I put a 9 1/2" dynamic in mine and took out the 11" 2200(observed) stall antique fairbanks.It was built for the 470 I'm building, but is running behind the old 383 for now.Haven't had it on the strip since, but if I short shift second gear under boost, it "stalls" at 4700 r.p.m.Right where I hoped it would.If it flashes there behind the 470 I'll be replacing an 8 3/4 soon after the next strip outing. At 65 m.p.h. cruise,(2770 r.p.m. by the math) it runs 50 r.p.m. higher than the old Fairbanks.It drives very nice and doesn't seem like a "high stall" converter at all after the car rolls about 3 feet from a dead stop.Any of the quality converter places can build you something like this, but my decision was heavily influenced by the price difference I was quoted.
Re: 2600-3000 stall converter... Which brand? [Re: 67_Satellite] #1722900
01/10/15 12:45 AM
01/10/15 12:45 AM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
After a few more calls and some more reading, I ordered a converter today. Decided on a Hughes Performance 3500 stall. It's a 10" unit and should do the trick for me and didn't break the bank.
Laine
Re: 2600-3000 stall converter... Which brand? [Re: Lmopar69] #1722901
01/10/15 04:51 AM
01/10/15 04:51 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Another point to really consider alot is if you plan to race it alot. To me thats a big difference because if you dont plan to race much then it has alot to do in how much money you spend. And you know if your not going to race it you can spend less money and not buy a top dollar race converter. The converter was very important in my build as I knew I was not going to race as much as I really wanted to but I wanted top perforrmance as I wanted it to work real good when I did race it and I knew I was going to spend the extra to get a top converter. Ron
Re: 2600-3000 stall converter... Which brand? [Re: 383man] #1722902
01/10/15 11:50 AM
01/10/15 11:50 AM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
You make a good point. We have a drag stip (kearney raceway) here in Nebraska, pretty close to me. I'll take it there to dial it all in, but I doubt it will truly fit into any class. Wasn't built for that. So, I'll race it when I can. They also do 1/8 mile drags here in hastings occasionally. Might be fun.
Biggest thing is, I must beat my older brother. Shouldn't be hard with this thing. He ran a 455 in a ratty Firebird on nitrous. Best time was an 11.13. I need to whoop him with a Mopar small block and no nitrous. Might take a cam change later on to do it. Maybe some more porting.... Whatever. Can't lose to a Pontiac.
Laine
Re: 2600-3000 stall converter... Which brand? [Re: Lmopar69] #1722903
01/10/15 02:44 PM
01/10/15 02:44 PM
RobX4406 Offline
RobX4406  Offline
If you spent 500-550ish on that converter, a custom one would have been ~100 more. More stall, tighter cruise from the custom.
Don't be surprised if that advertised 3500 stall isn't. I have a couple of those hughes convertes behind SB's. None stalled to advertised, most were 500 rpm short.
You're likely going to need in the 500hp range and great hook to get an 11.00 timeslip. Get it light and on a diet.
Sounds like a pretty cool D50.
Re: 2600-3000 stall converter... Which brand? [Re: RobX4406] #1722904
01/10/15 09:57 PM
01/10/15 09:57 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
With this engine as it is, your probably right on the stall speed. ET sounds like what I'm expecting initially too. Gotta start somewhere so I know where to go!
Also, wife said I can't work on any of my other cars/trucks till I finish this one! :-). Gotta get it done!
Laine
Re: 2600-3000 stall converter... Which brand? [Re: Lmopar69] #1722905
01/11/15 02:50 AM
01/11/15 02:50 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
No one mentioned...
http://www.edgeracingconverters.com/
I spoke with Andre and he asked a lot of questions. I feel confident in my choice.
I went with a 9-1/2" Street Edge 3200 stall for $490. Just showed up Wednesday, less than 2 weeks after order date. I'll have it installed in a few weeks
