look at a dana 60 truck rear to have cut..
#1719919
01/02/15 02:11 AM
01/02/15 02:11 AM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Gonna go look at a dana 60 tomarrow out of a truck guy said take 50 bucks so im gonna look I told him I just needed the bare housing. So hes gonna take the open center and pinnion out Is there anything to look for or to avoid? Im wanting to have cut down for car. Think is out of a late 60s early 70 ford truck
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: look at a dana 60 truck rear to have cut..
[Re: toplescuda]
#1719920
01/02/15 04:18 AM
01/02/15 04:18 AM
Posts: 43,232 Bend,OR USA
Cab_Burge
I would see what gear ratio it has and then decide if I wanted them based on the condition and price. What weight car, size motor and track length are you building the rear end for? I use to buy all the hurt junkyard Dana 60 I could get, especially those that had a bad axle end on them with 4.10 or lower gears( 4.30,4.56 and up ) and posi units You already stated it was a open rear so a spool will fix that easily. I have one out of a 3/4 or 1 ton van in the shop now that I had narrowed locally and new ends put on it. I bought a early clutch style posi unit from another member on here in the past and bought axles and the parts needed to convert the 30 spline posi to a 35 spline from Dr Diff. It is ready to go into its new home, 1966 dodge Coronet Deluxe, with the orignal 3:54 gears for street driving. 464 C.I. 440 motor with a NP 833 O.D. tranny, hopefully the gears are quite and the used tranny is good also
[Re: toplescuda]
#1719924
01/02/15 01:58 PM
01/02/15 01:58 PM
Posts: 656 Alberta
rustbuckett68
Alberta
That era Ford p/u had some 1/2T 5 bolt (5 on 5 1/2") axle Dana 60s. Most were power locks, I think.
[Re: rustbuckett68]
#1719929
01/02/15 07:15 PM
01/02/15 07:15 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Well I bought it. Just bare housing. It had a 3.55 open center I didnt need anyway. The tubes are 3" so thats good also Later will round up some ends. Came out of a 71 or 72 ford 3/4 ton
[Re: toplescuda]
#1719930
01/02/15 09:05 PM
01/02/15 09:05 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
I havent unloaded it from the truck bed yet. But was wondering. If it was not possible to drill n tap for a snubber? I havent decided wich car I will put this under yet (one has 4 link) more then likely will not be a issue. Just courious
[Re: astjp2]
#1719932
01/02/15 09:42 PM
01/02/15 09:42 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
I wont have to ship the rear nowhere to have to cut/welded. There is a few places here in the bluff that have narrowing jigs and that is what they do
[Re: Sport440]
#1719935
01/03/15 02:10 AM
01/03/15 02:10 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Its been raining here all day. I back tbe truck under the carport. With rear still in the bed.
