Lobe lift specs for solid MP Purple cams. #171966
12/20/08 08:34 PM
12/20/08 08:34 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I am building a 440 for a fellow Moparts member and he has a solid(3 bolt)Purple shaft with no paperwork and I was wondering what cam it was by checking lobe lift before I bolt it together.
Gus
64 Plymouth Savoy
Dana 60
Re: Lobe lift specs for solid MP Purple cams. [Re: fourgearsavoy] #171967
12/20/08 09:09 PM
12/20/08 09:09 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Gus You can just use the reverse math to find the lobe size of the cam that you have. While your lobe size wont match perfectly with the exact math it will be cose enough to determine Witch cam you have.
Example the lobe lifts for some of the purple shaft are as follows by dividing valve lift by 1.5 rocker ratio to get lobe height.
MP .528 = .352 lobe lift
MP .557 = .371 -------
MP .590 = .393 ----
I find the actual lobe lifts to generaly be just a little less then the Actual Math specs..
Example, if you measure a .370 lobe lift, You sure as heck dont have the .590 or the .528 stick, it would be the mp .557.
Even though the spec.doesnt match perfect to the math ,its close enough for the identification. mike
Re: Lobe lift specs for solid MP Purple cams. [Re: fourgearsavoy] #171968
12/20/08 09:10 PM
12/20/08 09:10 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
Here's a page with more specs that you normally find about the MP solid cams:
http://victorylibrary.com/mopar/mpcam-tech-c.htm
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
