67 RO/WO hoodscoop by hemieddy #1714653
12/23/14 02:33 PM
12/23/14 02:33 PM
Phoenix, AZ
Belvedere1 Offline OP
Phoenix, AZ
I've been looking for a high quality reproduction bolt-on scoop like the ones Kramer used to sell but he out of stock indefinitely but I noticed these on ebay from a seller out of Rochester, MI. Has anyone seen one of these in person or can comment on how they compare to the ones from Kramer?
http://www.ebay.com/itm/1966-1967-426-Ra...27b&vxp=mtr
Re: 67 RO/WO hoodscoop by hemieddy [Re: Belvedere1] #1714654
12/23/14 02:34 PM
12/23/14 02:34 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If you want a truely high quality 67 scoop you need one of Domingos steel reproductions.
This is a real one, it's not bolted on, just laying there for a pic to see how it looks, just a coincidence that it's red.
Re: 67 RO/WO hoodscoop by hemieddy [Re: ScottSmith_Harms] #1714655
12/23/14 02:56 PM
12/23/14 02:56 PM
Phoenix, AZ
Phoenix, AZ
I agree if $$ were no issue but a good fiberglass piece work for this type of car.
Re: 67 RO/WO hoodscoop by hemieddy [Re: Belvedere1] #1714656
12/23/14 03:48 PM
12/23/14 03:48 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I was pretty sure genies days scoop is the same as Kramers
I'd double check on availability because I think hemieddy and Kramer work yogethet on a bunch of parts together.
He might not have it in stock also.
Re: 67 RO/WO hoodscoop by hemieddy [Re: Belvedere1] #1714657
12/23/14 05:55 PM
12/23/14 05:55 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
I use this one and are happy with it.
Good quality piece.
https://www.aarqualityfiberglass.com/products/scoop-hemi-1966-1967-b-body-bolt
Re: 67 RO/WO hoodscoop by hemieddy [Re: actionange] #1714658
12/23/14 09:03 PM
12/23/14 09:03 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Good quality piece.
Hmmm...wonder how that looks on a 2 door post Valiant.
Re: 67 RO/WO hoodscoop by hemieddy [Re: actionange] #1714659
12/23/14 09:20 PM
12/23/14 09:20 PM
Phoenix, AZ
Phoenix, AZ
I had one of the stud mount type many years back and was not impressed.
Re: 67 RO/WO hoodscoop by hemieddy [Re: 451Cuda] #1714660
12/23/14 10:32 PM
12/23/14 10:32 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Looks nice.
Re: 67 RO/WO hoodscoop by hemieddy [Re: topbrent] #1714661
12/24/14 12:17 AM
12/24/14 12:17 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That one looks like a 64/65 style (lower profile than the 67's).
Re: 67 RO/WO hoodscoop by hemieddy [Re: ScottSmith_Harms] #1714662
12/24/14 01:47 AM
12/24/14 01:47 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Yeah it does!
Thanks for the pic.
Re: 67 RO/WO hoodscoop by hemieddy [Re: actionange] #1714663
12/24/14 01:55 PM
12/24/14 01:55 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Good quality piece.
Happy with the AAR scoop as well.
Re: 67 RO/WO hoodscoop by hemieddy [Re: G_bob] #1714664
12/24/14 08:59 PM
12/24/14 08:59 PM
Saskatchewan, Canada
barracudabob Offline
Glasstek make a nice one too. www.glasstek.com look under Belvedere.
Re: 67 RO/WO hoodscoop by hemieddy [Re: barracudabob] #1714665
12/24/14 09:09 PM
12/24/14 09:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Nothing against you guys who have glass scoops, all awesome cars, but I have yet to see a hemi scoop that didn't have at lease some bowing or sagging out accross the top flat surfaces. The design is just too large and flat for fiberglass to hold a true flat surface over so much area. Its more evident once you do a side by side with a steel one.
Re: 67 RO/WO hoodscoop by hemieddy [Re: barracudabob] #1714666
12/26/14 01:05 AM
12/26/14 01:05 AM
Phoenix, AZ
Phoenix, AZ
There isn't much of a description on the one from Glasstek so is it a bolt-on type with a flat flange and Tinnerman nuts like the ones from Kramer or is it a stud mounted type?
Re: 67 RO/WO hoodscoop by hemieddy [Re: Belvedere1] #1714667
12/26/14 01:23 AM
12/26/14 01:23 AM
Wi.
old_racer Online content
old_racer  Online Content
Wi.
my glass tek one has the flat flange and I use the slip on clip nuts with bolts from the bottom up thru the hood.
Russ
Re: 67 RO/WO hoodscoop by hemieddy [Re: old_racer] #1714668
12/26/14 02:07 AM
12/26/14 02:07 AM
Mine was the same way with the flange.
Re: 67 RO/WO hoodscoop by hemieddy [Re: barracudabob] #1714669
12/26/14 01:11 PM
12/26/14 01:11 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
Drilled for a Stinger/AAR scoop this week. It came with studs glassed in.
NMCA NSS 67 Coronet
