IR manifold for a small block? #171392
12/20/08 12:48 PM
12/20/08 12:48 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
I am bored and ther is too much snowe to drive the cuda so I am kickin around the idea of building an IR manifold for my stroker motor. My question is where is a good source of info about desighn like how long and fat runners should be, side draft or down draft, what carbs work best? Mabey someone knows of a manifold being produced
Motor will be a 414 stroker, mabey bigger if I can come up with more $$$ for a longer stroke. I have a pair of RHS magnum heads or aluminum mopar magnums 1.7 rockers and a XE268 cam. I mostly want to do it because it's different but I still want it to run good.
Re: IR manifold for a small block? [Re: HotRodDave] #171393
12/20/08 10:16 PM
12/20/08 10:16 PM
San Diego
formula S Offline
formula S  Offline
San Diego
I think your going to have A hard time finding carbs big enough. I know guys that run dual 2 barrel 48 webbers on VWs with 120cuin displacement, and they make about 150 to 200 horse power. I dont know how big webbers get, but the VW guys talk about 48s as being the biggest they can get
Re: IR manifold for a small block? [Re: formula S] #171394
12/22/08 01:36 AM
12/22/08 01:36 AM
Kalispell Mt.
Kalispell Mt.
I figure if I had 250 CFM intake flow X 8cyl I would need about 2000 CFM, mabey a couple 1000cfm dominators set up with identicle primarys and secondaries. Does any one have experiance with dominators on an IR manifold?
Re: IR manifold for a small block? [Re: HotRodDave] #171395
12/22/08 03:31 AM
12/22/08 03:31 AM
San Diego
formula S Offline
formula S  Offline
San Diego
You need carbs that were designed for I/R use holleys are not, they will not deal with pulse that an I/R set up creates. If you have ever looked at A webber, notice how tall it is, its 2 or 3 times taller than A holley and that is no accident. its made for managing I/R conditions, your going to spend A lot of money on dominators and time on your manifold to find out it wont work. But if you must have an I/R set up you can start here. http://www.ronsfuel.com/single2.cfm you could use their throttle bodies with EFI. you could also try kinsler or hillborn to name A couple. This way you could get the CFM your looking for.
Re: IR manifold for a small block? [Re: formula S] #171396
12/22/08 03:37 AM
12/22/08 03:37 AM
There was at one time Dominators made to suit IR
Dont know the part No. or if they are still available.
Re: IR manifold for a small block? #171397
12/22/08 03:46 AM
12/22/08 03:46 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
6214 was made for I/R applications but reversion problems were never solved & Holley killed it...
Re: IR manifold for a small block? [Re: 1_WILD_RT] #171398
12/22/08 08:36 AM
12/22/08 08:36 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
what about motorcycle carbs
Chrysler Firepower
Re: IR manifold for a small block? [Re: therocks] #171399
12/22/08 12:50 PM
12/22/08 12:50 PM
Kalispell Mt.
Kalispell Mt.
I have been looking at some motorcycly carbs but I think they are too small but I don't see flow rateings on them, just MM
Re: IR manifold for a small block? [Re: HotRodDave] #171400
12/22/08 01:55 PM
12/22/08 01:55 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The biggest motorcycle carbs TIKO are the S&S Super D, 2-1/4". However, they're side-draft, $$$, have no power circuit, and are intended for a 2 cylinder motor about the size of your cylinders.
You can buy Mikuni with 48mm throats, but over $200. each and IDT that's big enough.
Boffin Emeritus
Re: IR manifold for a small block? [Re: 1_WILD_RT] #171401
12/22/08 02:07 PM
12/22/08 02:07 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
6214 special venturi on the left...
Re: IR manifold for a small block? [Re: 1_WILD_RT] #171402
12/22/08 02:09 PM
12/22/08 02:09 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
6214 velocity stacks...
Re: IR manifold for a small block? [Re: 1_WILD_RT] #171403
12/22/08 04:46 PM
12/22/08 04:46 PM
Kalispell Mt.
Kalispell Mt.
A side draft may not be out of the question. I thought about getting some kinda air-gap manifold and cutting everything out except the bottom plate and flange area, then weld in some tubes to cross over and sit the carbs on the oposite side valve cover area.
Are those 2cyl motorcycle carbs 1 throat or 2? Are the cylinders the size of mine individually or combined?
A mototrcycle carb may be fine because they are desighned to feed a smaller engine but at two to three times the RPM.
If a carb is going to feed a 25 cubic inch 1 cyl @ 10,000 rpm it should feed my 50 cubic inch cylinder @ 5000 rpm, is that close to correct?
Re: IR manifold for a small block? [Re: HotRodDave] #171404
12/22/08 04:50 PM
12/22/08 04:50 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Just wondering by why would you even want to do this?...
Re: IR manifold for a small block? [Re: dizuster] #171405
12/22/08 05:11 PM
12/22/08 05:11 PM
San Diego
formula S Offline
formula S  Offline
San Diego
first three words in his orignal post "I am bored"
Re: IR manifold for a small block? [Re: formula S] #171406
12/22/08 05:15 PM
12/22/08 05:15 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Gonna spent alot of time & money on something thats been problematic & never proven any big gains in the past...
Might be a better idea to take up Bowling..At least every bowler I know drinks...
Re: IR manifold for a small block? [Re: formula S] #171407
12/22/08 05:21 PM
12/22/08 05:21 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yeah but if you were board, don't you think you'd at least try to do something to make the car faster...not slower? lol...
Re: IR manifold for a small block? [Re: dizuster] #171408
12/22/08 05:35 PM
12/22/08 05:35 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
first three words in his orignal post "I am bored "
Yeah but if you were board , don't you think you'd at least try to do something to make the car faster...not slower? lol...
Must have wood....
Re: IR manifold for a small block? [Re: 1_WILD_RT] #171409
12/22/08 06:38 PM
12/22/08 06:38 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The s&s super carbs you can run em on one cyl or two and they put the on 120in motors that only turn about 6000
Chrysler Firepower
Re: IR manifold for a small block? [Re: HotRodDave] #171410
12/22/08 07:21 PM
12/22/08 07:21 PM
New York
polyspheric Offline
polyspheric  Offline
New York
All 1 throat
Each
Yes, I know that's what the "formula" shows, but it doesn't work. The small cylinder need a small carb or it has poor response, the big cylinder needs a big carb or it has no power.
Cutting off everything but the flange and chunk of the runner and extending them across is exactly what a 1960-61 Chrysler long ram runners look like (except they ended in plenums). There are also Moon Weber manifolds like that - there's no other way to hide the length and put the hood on.
I agree - it's a lot of trouble without much gain - and that's if you get it right. Most people give up after much $$$ and &<?$@~`**!!!!.
Boffin Emeritus
Re: IR manifold for a small block? [Re: polyspheric] #171411
12/23/08 12:21 AM
12/23/08 12:21 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
why not efi the setup? that way you can still run the IR manifold with individual throttle bodies and youre at least guaranteed a workable solution at the end.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
