Re: Drag race trucks
[Re: mechanic190]
#1713068
12/20/14 02:23 PM
12/20/14 02:23 PM
Posts: 4,988 new jersey usa
11secdart
new jersey usa
Not as old as yours but here goes: 92 D150 5.2 , 518 auto. 4.10 gears w/ sure-grip ( came 3.55 open) has ran a best of 15.19. with a 2.04 60 ft, average 15.20-30s, M/P computer, M/P shift kit, Ultimate prepped lock-up converter, t/b spacer, Summit shorty headers, 3 inch single exhaust w/ Flowmaster 40 muffler, Spectre ram air system, M/T drag radials, swap meet traction bars w/ Rancho shocks, I have a 360 Magnum short block to do for it someday.
[Re: 11secdart]
#1713070
12/20/14 07:51 PM
12/20/14 07:51 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Not a full size but a Dodge D50 with a pump gas small block. Drove to track and ran a best of 6.29 @ 109 with a 1.33 60 ft. so far . Just upgraded the fuel system from a mechanical fuel pump to a Magnafuel electric with bigger lines and hope to run faster in the spring. All motor.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1713071
12/20/14 08:09 PM
12/20/14 08:09 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I love your D50 My Dad had one those (Mitsubishi, 2.0 & 5 speed) and it was lots of fun...I can only imagine what a rocket it would have been if it had a pump gas small block in place of the 2.0. I don't fit in those small trucks anymore, so I am going with a Ramcharger. I bought mine off CL about 6 years ago and the project is moving a little slower than I would like, but I have the basics, a Cab Burge built 440, Pat Blais built RMVB 727, spooled Dana 60 with 4.10s... and better yet, I have a great place to build it. BTW from personal experience, don't expect the fuel system mods to make an immediate difference in ET. What you are doing is preparing for the next step up in fuel demand...better to have it in place first. Good Luck
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: mechanic190]
#1713078
12/21/14 01:16 AM
12/21/14 01:16 AM
Posts: 142 Chattanooga, TN
KDY
Chattanooga, TN
I just finished mine up after a 3 year build. Stock bore and stroke cast crank motorhome 440, kb184 pistons, mp stage 5 iron heads (flow 265/187 @ .500), comp 274 cam, Holley street dominator and a Holley 650dp. 727 with a 8" converter and a Dana 60 with 4.10s. Weighs 3520 full of fuel and no driver....3770 with me in it. Been a best of a 7.66 @ 87.89 with a 1.63 60ft. 7.5x will happen with a bit more tuning. Here's a video: http://youtu.be/j2kuqMl3NG0I'm thrilled to death with this simple little combo. Big thanks to 727builder for all his help!
[Re: KDY]
#1713080
12/21/14 03:53 AM
12/21/14 03:53 AM
Posts: 15,487 Florida
scratchnfotraction
my 440/727/ A-body 8 3/4- 3.91sg FYI,,, A-body 8 3/4 shares same 43" perch centers and bolts in on top of springs with a shackle flip to tuck 12" rims with a 29x15x15 M/T in the fenders bed tubbed to frame. with a stock truck axle a 10 rim with 7.5 backset will tuck the 29 M/T in there with it tubbed as well my 73 c-body 8 3/4 same as 72 truck 8 3/4 at 59" flange to flange my 67-c-body 8 3/4 is 56" flange to flange. nice for 10" rims
[Re: scratchnfotraction]
#1713082
12/21/14 12:09 PM
12/21/14 12:09 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
although not a full size.. I had a '94 Dakota street/strip. 440,727, 3500 PTC, '68 B body 8 3/4 with a 4.10 Sure Grip. My best pass was an 11.72. Here's a vid of a different pass.. No, I didn't use nitrous.. that was the other lane.. http://s242.photobucket.com/user/KatFysh...?sort=3&o=0this was at the Mopar Nats, Moparts car club parking. http://i242.photobucket.com/albums/ff249/KatFysh-4/The%20440%20Dakota/MoparNats08040.jpg
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: KDY]
#1713083
12/22/14 12:29 AM
12/22/14 12:29 AM
Posts: 727 Ottawa, ontario
dd340
Ottawa, ontario
Been a best of a 7.66 @ 87.89 with a 1.63 60ft. 7.5x will happen with a bit more tuning. !
What are you doing for suspension and tires to get that truck hooked up? My d100 will hit 86mph in the 1/8th mile but I have absolutely no traction.
[Re: mechanic190]
#1713084
12/22/14 12:52 AM
12/22/14 12:52 AM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
I built this truck in '87 with a freshened '76 440 with a .509 purple shaft and a Holley street dominator intake w/ a 800 Holley. rebuilt 727 w/home made manual shift VB and stock Tq converter. Out back I moved the truck springs under the frame and put a B body Dana 60 w/5.13. and slapper bars and pinion snubber. I cut the stock tubs and moved them. Rear tires were 14 X32's
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#1713085
12/22/14 12:54 AM
12/22/14 12:54 AM
W.I.N. Racing
Byron, NY
with a 426 Hemi and better trans and converter
[Re: dd340]
#1713086
12/22/14 01:00 AM
12/22/14 01:00 AM
Posts: 1,365 elmira ny
hp340nos
elmira ny
my 88 dakota street/strip,pump gas 340 stroker,727,8 3/4.m/t drag radial.has been 7.30@95 on motor and 6.84@102 on 100 shot,raced as driven on the street and 45 minutes to the track.
