how does a radiator cap work #171280
12/20/08 06:26 AM
12/20/08 06:26 AM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
How does the pounds of a radiator cap work with the cooling system? Brad
Re: how does a radiator cap work [Re: roadrunnerreds] #171281
12/20/08 07:17 AM
12/20/08 07:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Not really sure of the question but with every psi
that you increase in the system you raise the boiling
point 3*. There is 2 types of radiator caps 1 for
a resvoir(recovery style system and non resvoir)
and the easy way to tell if you have the resvoir cap
is, if you hold the cap up right there is a metal plate
dangling down, the non resvoir doesnt have it dangling
Re: how does a radiator cap work [Re: roadrunnerreds] #171282
12/20/08 12:40 PM
12/20/08 12:40 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Re: how does a radiator cap work [Re: roadrunnerreds] #171283
12/21/08 01:23 AM
12/21/08 01:23 AM
Gettysburg Pa
Gettysburg Pa
just wanted to get an idea if i have the right cap on my dart. if i let it sit running it goes up to 200-210 degrees with a 180 thermostat.i put a 22 inch radiator in it fan might be a little small it is a 15 inch no shroud.thought about putting a 16 electric fan with thermostatic control on it. thanks Brad
