Jesel belt drive and ATI Dampener on BB
#1712079
12/17/14 07:55 PM
12/17/14 07:55 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
For those of you that run Jesel belt drive and ATI Dampener did you have to use an extended snout hub on the Dampener?
If so what part number did you buy and is that the Chevy face or Mopar face?
I'm running the 917120 with Chevy face on my Australian Belt drive but I had to make a 1/4" spacer for it work with the Belt Drive.
I'm hoping I won't have to with the Jesel but wanted to ask.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Jesel belt drive and ATI Dampener on BB
[Re: sc301v]
#1712081
12/17/14 09:38 PM
12/17/14 09:38 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Should not need anything. The Australian belt drives required a spacer for sure.
[Re: Airwoofer]
#1712087
12/18/14 02:16 PM
12/18/14 02:16 PM
Jerry Kathe
Hmmmm....the fuel cranks im familiar with are splined...not keywayed... I know what your talking about though, sorry cant help you with the PN. You may consider ebay'ing your old one and just call ATI on your new requirement. You may also want to spin that shaft up and make sure you can rebalance to your needs before you commit. You may be unhappy with the results. ...
