Page 3 of 3 1 2 3
Re: Flowbench testing heads at MORE than 28" H2O? [Re: 1320Dart] #1711979
12/19/14 07:33 PM
12/19/14 07:33 PM
Washington
madscientist Offline
Washington
Evidently, that only happens if you agree with standard, regurgitated nonsense.
Re: Flowbench testing heads at MORE than 28" H2O? [Re: madscientist] #1711980
12/19/14 07:37 PM
12/19/14 07:37 PM
dogdays Offline
dogdays  Offline
For once I agree completely with Polyspheric. Technically correct answers!
R.
Re: Flowbench testing heads at MORE than 28" H2O? [Re: madscientist] #1711981
12/19/14 07:58 PM
12/19/14 07:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You don't have to spend all day at the bench if you know what you are doing. It's that simple. I don't use higher than 28" test pressures to inflate numbers. If you had as much flow bench time as you say you do, you would get that.
I'm going to race my 9 second torque wrench on Sunday. Whatcha got for that?
I tested at 28"... for the rest of it.. I wont even
respond... have a good day... back to your post Brad
Re: Flowbench testing heads at MORE than 28" H2O? [Re: madscientist] #1711982
12/19/14 08:15 PM
12/19/14 08:15 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
This is just my opinion, but if people are repeating incorrect statements, then those that know the correct ways, should teach/show why its incorrect. And try to help the rest of us by doing that at the same time.
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: Flowbench testing heads at MORE than 28" H2O? [Re: MR_P_BODY] #1711983
12/19/14 09:48 PM
12/19/14 09:48 PM
Washington
Washington
I test at 38, 32, 38, 42 regularly. I now have the ability to test at 60" inches plus some.
So what you really want is for those of you didn't pay for something be given that for free, just because of the internet?
I will say this...if your cylinder head porter does not test at a MINIMUM of 28" all the time, and is not using higher test pressures on a regular basis (especially with the intake system installed on the head) you are just pissing performance away.
It's that simple.
Comp, Pro Stock, Azzcar (and I know for a FACT Stock and SS guys) are testing at pressures up to 100"!!!!!!!!!!!!!!!!!! They ain't doing it to post big numbers and run their mouths on MoParts. They are doing it for RESULTS.
Take that to the bank.
Re: Flowbench testing heads at MORE than 28" H2O? [Re: madscientist] #1711984
12/19/14 09:56 PM
12/19/14 09:56 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Which goes back to the original reason why I posted this, i.e. what I'd heard re: the benefits of testing at > 28" H2O.
Re: Flowbench testing heads at MORE than 28" H2O? [Re: madscientist] #1711985
12/19/14 09:58 PM
12/19/14 09:58 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Are you specifically talking to me? What did I say about big numbers? I said flow at two different test pressures and consider the results.
I can tell from your comments that your time with a flow bench is limited.
As for the guy who has never pulled to the line and raced a flow bench...how silly can you be? Every serious shop has a flow bench a dyno.
They also have torque wrenches and ring compressers too. Bet you never raced either of those?
you do know Mr. P was a flow engineer at Mopar correct?
Re: Flowbench testing heads at MORE than 28" H2O? [Re: Quicktree] #1711986
12/19/14 10:02 PM
12/19/14 10:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not true Tony but I did do a lot of flow work
Re: Flowbench testing heads at MORE than 28" H2O? [Re: MR_P_BODY] #1711987
12/19/14 10:04 PM
12/19/14 10:04 PM
Q
Quicktree Offline
Quicktree  Offline
Q
hell i thought you were an engineer?
Re: Flowbench testing heads at MORE than 28" H2O? [Re: Quicktree] #1711988
12/19/14 10:05 PM
12/19/14 10:05 PM
Washington
Washington
So what if he was? He still puts his pants on one leg at a time right?
Test and LEARN for yourself.
Unless you can prove to me that you (or anyone else) wrote the 10 Commandment in stone with your own finger, I won't take what is said as gospel. Regardless of who anyone works (or worked) for.
Re: Flowbench testing heads at MORE than 28" H2O? [Re: Quicktree] #1711989
12/19/14 10:07 PM
12/19/14 10:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Nope... just a mech/tech on pre proto and proto stuff
and a lot of R&D
Re: Flowbench testing heads at MORE than 28" H2O? [Re: madscientist] #1711990
12/19/14 10:09 PM
12/19/14 10:09 PM
Q
Quicktree Offline
Quicktree  Offline
Q
why are you being so dam nasty?
Re: Flowbench testing heads at MORE than 28" H2O? [Re: MR_P_BODY] #1711991
12/19/14 10:10 PM
12/19/14 10:10 PM
Q
Quicktree Offline
Quicktree  Offline
Q
and a lot of R&D
ok close enough
Re: Flowbench testing heads at MORE than 28" H2O? [Re: Quicktree] #1711992
12/20/14 02:42 AM
12/20/14 02:42 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Because he thinks his bench is bigger than yours.
Can anybody give me a rough idea if you had a bench that can pull 28" thru a 4" pipe, how much could it pull on a typical wedge head port?
We'll see whose is bigger
Kevin
Re: Flowbench testing heads at MORE than 28" H2O? [Re: BradH] #1711993
12/20/14 11:01 AM
12/20/14 11:01 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Thinking about it dynamically you would think lower lift should be tested at lower pressure because the piston is not moving very fast or forcefully compared to 1/3 to 1/2 way down the bore when the valve is open and piston speed is high. Also if the ex valve is open it is just scavenging depression causing the flow witch surely is not 36 inches.
I disagree, low lift is when it is moving the fastest during the overlap period and right after the exhaust valve closes, after that
Well, you're kind of(?) both wrong.
This graph from David Vizard's most recent porting book may help you understand what's going on w/ the in-cylinder pressures and seat / port velocities:
1. Highest is during overlap (at higher RPM, at least) due to exhaust-assisted low pressure
2. Lowest is as the intake cycle is closing; might even go in reverse as you get into reversion if the valve doesn't close soon enough
3. Peak after the overlap cycle has ended is shown around the 70-75* ATDC point where, in this particular graph, the pressure differential is bouncing around the 50" H20 mark
Wow. The graph has a pile of great info in it. Thanks
Re: Flowbench testing heads at MORE than 28" H2O? [Re: Quicktree] #1711994
12/20/14 11:37 AM
12/20/14 11:37 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
How inefficient.
I've learned about gravity and balance and stuff a while ago and nowadays I always use both legs and pull up the pants in 1 or 2 go's, all while sitting down ofcourse.
Re: Flowbench testing heads at MORE than 28" H2O? [Re: BigBlockMopar] #1711995
12/20/14 11:51 PM
12/20/14 11:51 PM
Washington
Washington
Proud of you dude, you put on your pants with both legs at once.
Guess that makes you a professional head porter?
Re: Flowbench testing heads at MORE than 28" H2O? [Re: madscientist] #1711996
12/21/14 08:35 AM
12/21/14 08:35 AM
The Netherlands
The Netherlands
Almost, but I've ported my pants for more flow, at 28" by the way. Makes 2-leg entries much smoother...
It's all about using your head... Ho, ho, ho...
Re: Flowbench testing heads at MORE than 28" H2O? [Re: BigBlockMopar] #1711997
12/21/14 12:37 PM
12/21/14 12:37 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
It's truly winter time on Moparts.
Re: Flowbench testing heads at MORE than 28" H2O? [Re: Duner] #1711998
12/26/14 04:36 PM
12/26/14 04:36 PM
BradH Offline OP
BradH  Offline OP
Any chance we can try to keep this on topic... more or less?
Page 3 of 3 1 2 3
