Page 1 of 3 1 2 3
Flowbench testing heads at MORE than 28" H2O? #1711939
12/17/14 03:38 PM
12/17/14 03:38 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Who here that does flowbench testing w/ large-capacity flowbenches tests at HIGHER than 28" H2O, even though 28" is the standard?
I've read some stuff on SpeedTalk, et al, where some well-known head porters recommend testing at 36" (or higher, if your bench can pull it) because certain flow issues don't show up at lower test depressions.
As I'm considering a flowbench upgrade, part of what I'm taking into account is flow capabilities at both 28" and 36" for just this reason. Therefore, I'd be interested in hearing about examples of testing at higher than 28" revealed issues that were able to be resolved from refinement / revision to the port design.
Thanks,
Brad
Re: Flowbench testing heads at MORE than 28" H2O? [Re: BradH] #1711940
12/17/14 03:49 PM
12/17/14 03:49 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I'm pretty sure Smokey Yunick was a proponent of that for the reasons you state.
My builder does it too for the same reasons.
I posted pics of his equipment in your other thread. It will easily pull 28" on a 4" open pipe so he can dial up whatever he needs over 28" on a port.
Kevin
Re: Flowbench testing heads at MORE than 28" H2O? [Re: Twostick] #1711941
12/17/14 05:17 PM
12/17/14 05:17 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
well, what if you have a jacked up short turn that shows up at 28 but not at 36? does that mean that the short turn is ok now because your pulling so hard on the port that it doesn't show up?
I know Smokey went thru this when he decided that 28 should be the number. How many inches is the piston pulling once its past halfway down the bore?
Re: Flowbench testing heads at MORE than 28" H2O? [Re: BradH] #1711942
12/17/14 05:25 PM
12/17/14 05:25 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: Flowbench testing heads at MORE than 28" H2O? [Re: 1320Dart] #1711943
12/17/14 05:33 PM
12/17/14 05:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Thinking about it dynamically you would think lower lift should be tested at lower pressure because the piston is not moving very fast or forcefully compared to 1/3 to 1/2 way down the bore when the valve is open and piston speed is high. Also if the ex valve is open it is just scavenging depression causing the flow witch surely is not 36 inches.
Re: Flowbench testing heads at MORE than 28" H2O? [Re: sixpackgut] #1711944
12/17/14 05:33 PM
12/17/14 05:33 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If it shows up at 28 as a SMALL issue it may or may not get any worse but if it does get worse in my testing the issue needs addressed. I can only go to about 34 inches on my bench. Lots of discussions on this but it still comes down to the fact that a valve is at .500 twice and .700 once, that is if you have a 750 lift cam by time lash and pushrods deflection is factored in.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Flowbench testing heads at MORE than 28" H2O? [Re: HotRodDave] #1711945
12/17/14 05:39 PM
12/17/14 05:39 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
I disagree, low lift is when it is moving the fastest during the overlap period and right after the exhaust valve closes, after that
Re: Flowbench testing heads at MORE than 28" H2O? [Re: sixpackgut] #1711946
12/17/14 06:33 PM
12/17/14 06:33 PM
BradH Offline OP
BradH  Offline OP
Well, you're kind of(?) both wrong.
This graph from David Vizard's most recent porting book may help you understand what's going on w/ the in-cylinder pressures and seat / port velocities:
1. Highest is during overlap (at higher RPM, at least) due to exhaust-assisted low pressure
2. Lowest is as the intake cycle is closing; might even go in reverse as you get into reversion if the valve doesn't close soon enough
3. Peak after the overlap cycle has ended is shown around the 70-75* ATDC point where, in this particular graph, the pressure differential is bouncing around the 50" H20 mark
Re: Flowbench testing heads at MORE than 28" H2O? [Re: pittsburghracer] #1711947
12/17/14 06:40 PM
12/17/14 06:40 PM
BradH Offline OP
BradH  Offline OP
I keep reading on SpeedTalk where folks talk about ports looking just fine at 28", but then go all to kwap at 36-40". Supposedly, even if the flow #s don't increase at 28" after correcting the issue, the engines run better once the issue found at the higher test pressure is resolved.
I know I've had some heads on my "toy" bench that didn't sound good even at 10". Would be really interested in knowing what they do at 28", and then even higher.
Re: Flowbench testing heads at MORE than 28" H2O? [Re: BradH] #1711948
12/17/14 07:11 PM
12/17/14 07:11 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I'm sure this is a stupid question, but why not test flow at a vacuum level similar to the actual port at wide open throttle? Like 1 inch? WOuldn;t that be a more realistic test of the ports performance in the engine?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Flowbench testing heads at MORE than 28" H2O? [Re: Hemi_Joel] #1711949
12/17/14 07:21 PM
12/17/14 07:21 PM
BradH Offline OP
BradH  Offline OP
The 1.0" to 1.5" WOT pressure at the carb isn't the same as the pressure seen (felt?) by the head & cylinder during the intake & exhaust cycle. Same engine, but very different conditions being experienced in different locations of the induction system.
Re: Flowbench testing heads at MORE than 28" H2O? [Re: BradH] #1711950
12/17/14 08:23 PM
12/17/14 08:23 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Well if thats the case, it looks like you should be using much higher vac. According to Vizard's graf and comments
Re: Flowbench testing heads at MORE than 28" H2O? [Re: Hemi_Joel] #1711951
12/17/14 08:58 PM
12/17/14 08:58 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
When we measure flow on a flowbench, we are measuring at 28" h2o. The vacuum measurements you take at the carburetor are measured in "hg
1"hg is close to 13.6" h2o.
When Smokey came up with 28" for a standard he was assuming 2" h2o was the average and converted that number.
Keith
Re: Flowbench testing heads at MORE than 28" H2O? [Re: sixpackgut] #1711952
12/17/14 09:01 PM
12/17/14 09:01 PM
PA.
"Little"John
"Little"John
PA.
28 has been used as a industry standard for so long because it works and is trusted in the high performance market. Go to Stan Weises website and every head is at 28 inches. WHY Super Flow sets their benches up for 25 inches of depression always bothered me and is one reason I would never buy one of their benches. Even their high output models test at 25 inches.
http://www.superflow.com/Flowbenches/
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Flowbench testing heads at MORE than 28" H2O? [Re: Dunnuck Racing] #1711953
12/17/14 10:26 PM
12/17/14 10:26 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Keith
Great info, thanks!
Re: Flowbench testing heads at MORE than 28" H2O? [Re: BradH] #1711954
12/17/14 11:08 PM
12/17/14 11:08 PM
BradH Offline OP
BradH  Offline OP
My bad... also forgot about the Hg vs. H2O difference that Keith D. pointed out.
Re: Flowbench testing heads at MORE than 28" H2O? [Re: BradH] #1711955
12/18/14 01:04 AM
12/18/14 01:04 AM
AndyF Online content
AndyF  Online Content
Back in my engineering days we called this "four corner" testing. That is, you just push a test as far as you can in each dimension to see what happens. Maybe you find something, maybe you don't. If you don't find something you haven't proven that something doesn't exist, just that you didn't find it.
You can spend a huge amount of time and money doing this so you have to be a little careful. Having a test plan helps. Not being crazy also helps.
Re: Flowbench testing heads at MORE than 28" H2O? [Re: pittsburghracer] #1711956
12/18/14 01:27 AM
12/18/14 01:27 AM
Washington
madscientist Offline
Washington
Just because 28 is the defacto standard means nothing. What looks good at 10" won't work at 28" (as seen by early ported stuff when a superflow bench top was the cats buttocks).
So...if you flow something at 28" and then test it at 32" (or more) and the port doesn't keep up mathematically...you need to fix it.
It's that simple.
FWIW...the higher the test pressure the better.
Re: Flowbench testing heads at MORE than 28" H2O? [Re: madscientist] #1711957
12/18/14 02:01 AM
12/18/14 02:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It's that simple.
As usual a lot of people put way to much into the
flow numbers... we have all seen this... big flowing
heads that SUCKED on the track... you can spend all
sorts of time TRYING to come up with the perfect set
of heads on a flow bench... but.. I've never pulled
up to the line next to a flow bench.. and everyone
will agree that the best dyno is the track
Re: Flowbench testing heads at MORE than 28" H2O? [Re: MR_P_BODY] #1711958
12/18/14 03:37 AM
12/18/14 03:37 AM
SoCal
Brian Hafliger Offline
SoCal
Nobody has even mentioned RPM and it's effect on port speed...
Brian Hafliger
Page 1 of 3 1 2 3
