Re: Flowbench testing heads at MORE than 28" H2O?
[Re: Twostick]
#1711941
12/17/14 05:17 PM
12/17/14 05:17 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
well, what if you have a jacked up short turn that shows up at 28 but not at 36? does that mean that the short turn is ok now because your pulling so hard on the port that it doesn't show up?
I know Smokey went thru this when he decided that 28 should be the number. How many inches is the piston pulling once its past halfway down the bore?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: BradH]
#1711942
12/17/14 05:25 PM
12/17/14 05:25 PM
Posts: 503 Idaho
1320Dart
Idaho
Greg ----------------------------------------------------------------- Cost is irrelevant, making memories is far more valuable!
[Re: 1320Dart]
#1711943
12/17/14 05:33 PM
12/17/14 05:33 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Thinking about it dynamically you would think lower lift should be tested at lower pressure because the piston is not moving very fast or forcefully compared to 1/3 to 1/2 way down the bore when the valve is open and piston speed is high. Also if the ex valve is open it is just scavenging depression causing the flow witch surely is not 36 inches.
[Re: sixpackgut]
#1711946
12/17/14 06:33 PM
12/17/14 06:33 PM
BradH
I disagree, low lift is when it is moving the fastest during the overlap period and right after the exhaust valve closes, after that
Well, you're kind of(?) both wrong.
This graph from David Vizard's most recent porting book may help you understand what's going on w/ the in-cylinder pressures and seat / port velocities: 1. Highest is during overlap (at higher RPM, at least) due to exhaust-assisted low pressure 2. Lowest is as the intake cycle is closing; might even go in reverse as you get into reversion if the valve doesn't close soon enough 3. Peak after the overlap cycle has ended is shown around the 70-75* ATDC point where, in this particular graph, the pressure differential is bouncing around the 50" H20 mark
[Re: pittsburghracer]
#1711947
12/17/14 06:40 PM
12/17/14 06:40 PM
BradH
If it shows up at 28 as a SMALL issue it may or may not get any worse but if it does get worse in my testing the issue needs addressed.
I keep reading on SpeedTalk where folks talk about ports looking just fine at 28", but then go all to kwap at 36-40". Supposedly, even if the flow #s don't increase at 28" after correcting the issue, the engines run better once the issue found at the higher test pressure is resolved.
I know I've had some heads on my "toy" bench that didn't sound good even at 10". Would be really interested in knowing what they do at 28", and then even higher. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: BradH]
#1711948
12/17/14 07:11 PM
12/17/14 07:11 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I'm sure this is a stupid question, but why not test flow at a vacuum level similar to the actual port at wide open throttle? Like 1 inch? WOuldn;t that be a more realistic test of the ports performance in the engine? ![](/ubbthreads/images/graemlins/confused.gif)
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#1711949
12/17/14 07:21 PM
12/17/14 07:21 PM
BradH
The 1.0" to 1.5" WOT pressure at the carb isn't the same as the pressure seen (felt?) by the head & cylinder during the intake & exhaust cycle. Same engine, but very different conditions being experienced in different locations of the induction system.
[Re: BradH]
#1711950
12/17/14 08:23 PM
12/17/14 08:23 PM
sixpackgut
Charleston
Well if thats the case, it looks like you should be using much higher vac. According to Vizard's graf and comments
[Re: Hemi_Joel]
#1711951
12/17/14 08:58 PM
12/17/14 08:58 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
When we measure flow on a flowbench, we are measuring at 28" h2o. The vacuum measurements you take at the carburetor are measured in "hg 1"hg is close to 13.6" h2o. When Smokey came up with 28" for a standard he was assuming 2" h2o was the average and converted that number. Keith
[Re: Dunnuck Racing]
#1711953
12/17/14 10:26 PM
12/17/14 10:26 PM
Hemi_Joel
Minnesota
Great info, thanks! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: BradH]
#1711954
12/17/14 11:08 PM
12/17/14 11:08 PM
BradH
My bad... also forgot about the Hg vs. H2O difference that Keith D. pointed out. ![](/ubbthreads/images/graemlins/whistling.gif)
#1711956
12/18/14 01:27 AM
12/18/14 01:27 AM
Posts: 4,457 Washington
madscientist
Washington
Just because 28 is the defacto standard means nothing. What looks good at 10" won't work at 28" (as seen by early ported stuff when a superflow bench top was the cats buttocks).
So...if you flow something at 28" and then test it at 32" (or more) and the port doesn't keep up mathematically...you need to fix it.
It's that simple.
FWIW...the higher the test pressure the better.
[Re: madscientist]
#1711957
12/18/14 02:01 AM
12/18/14 02:01 AM
Posts: 52,972 Romeo MI
MR_P_BODY
It's that simple.
As usual a lot of people put way to much into the flow numbers... we have all seen this... big flowing heads that SUCKED on the track... you can spend all sorts of time TRYING to come up with the perfect set of heads on a flow bench... but.. I've never pulled up to the line next to a flow bench.. and everyone will agree that the best dyno is the track ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1711958
12/18/14 03:37 AM
12/18/14 03:37 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Nobody has even mentioned RPM and it's effect on port speed...
Brian Hafliger
