727 Dipstick and Tube Finish #1710397
12/14/14 01:10 PM
12/14/14 01:10 PM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
Just wondering if anybody can tell me what the factory color/ finish was on a 727 Torquelite dipstick and tube on a 1970 340. Mine were bead blasted during rebuilding. Pictures I took before appear to be a phosphate finish but I really can't tell for certain.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 727 Dipstick and Tube Finish [Re: FJR doc] #1710398
12/14/14 01:45 PM
12/14/14 01:45 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Phosphate Tube
Natural Handle
Re: 727 Dipstick and Tube Finish [Re: AAR#2] #1710399
12/14/14 09:14 PM
12/14/14 09:14 PM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
Thanks AAR#2. Looks like I'll put some RPM on the handle and figure out how to phosphate the tube.
Kevin
Re: 727 Dipstick and Tube Finish [Re: FJR doc] #1710400
12/15/14 10:23 AM
12/15/14 10:23 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Zinc Phosphate is easily done at home, chemicals can be purchased from Brownells and then you need a stainless pot, pretty large one in this case. I have a friend who's a pool guy, some old DE filter canisters were stainless so we cut the top off, welded a plug in the bottom and now I have a LARGE pot for cooking. It worked perfectly for the rear brake backer plates as well. I have a smaller stainless bowl I use for small jobs like fasteners.
Good luck
Re: 727 Dipstick and Tube Finish [Re: FJR doc] #1710401
12/15/14 04:29 PM
12/15/14 04:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Eastwood has a phosphate paint that looks like the original.
http://www.eastwood.com/ew-zinc-phosphat...CFQdsfgod8BcA3g
Re: 727 Dipstick and Tube Finish [Re: John_Kunkel] #1710402
12/15/14 04:46 PM
12/15/14 04:46 PM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
I read about that product but couldn't find any pictures of how it looked after application. I will probably take the tube to my local plater and let them finish it for me.
Kevin
