89 Dakota 3.9 Won't Start #1710137
12/13/14 03:54 PM
12/13/14 03:54 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Drive it on my 2 days off every week. Never an issue. Today would not turn over. No clicking sound, nothing. Lights, radio all work. Ideas where to start?
Grandma always said I had "hands of gold"!
Re: 89 Dakota 3.9 Won't Start [Re: CHRGR69] #1710138
12/13/14 04:11 PM
12/13/14 04:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try moving the shifter from park to neutral while holding the key in the start position. Be sure your foot is on the brakes. If that doesn't work try jumping the two silver terminals on the starter relay with a screwdriver.
Re: 89 Dakota 3.9 Won't Start [Re: stumpy] #1710139
12/13/14 04:28 PM
12/13/14 04:28 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
I did try park and neutral, but not while holding the key in start. If jumping the terminals doesn't turn it, starter? And if it turns P to N, safety neutral switch?
Re: 89 Dakota 3.9 Won't Start [Re: CHRGR69] #1710140
12/13/14 04:57 PM
12/13/14 04:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it starts by jumping then probably the NSS if it starts while moving the shifter probably linkage adjustment. If neither works then jump the starter terminals. If that doesn't work then it's starter. Have you had the battery checked and charged? With the headlights on does trying to start the truck kill them? Another way to check the NSS is to ground the starter relay terminal that the NSS wire plugs onto. If the truck starts then that points to the NSS or linkage adjustment.
Re: 89 Dakota 3.9 Won't Start [Re: stumpy] #1710141
12/13/14 05:23 PM
12/13/14 05:23 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Thanks Will let you know what I find.
Re: 89 Dakota 3.9 Won't Start [Re: stumpy] #1710142
12/15/14 10:44 PM
12/15/14 10:44 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
It was the battery all along Stump. Good to go now!
Re: 89 Dakota 3.9 Won't Start [Re: CHRGR69] #1710143
12/16/14 02:37 AM
12/16/14 02:37 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
