Page 1 of 3 1 2 3
A body engine swap discovery #17095
08/16/05 10:15 PM
08/16/05 10:15 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
I do not know if anybody else is aware of this but here goes, I have a 69 Valiant with a slant six k member and I am in the process of building a 340 for it, anyway I was messing around in the shop and I took a 340 block and associated brackets and started mocking the block up.
This is what I found, using the correct drivers side mount(340 block 340 bracket) and on the passenger side I used a van or truck mount and it dropped right in, now this was only the block, my next step is an engine and trans.
I have some pics but they are not great.
Re: A body engine swap discovery [Re: RV2] #17096
08/16/05 10:16 PM
08/16/05 10:16 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
pic
Re: A body engine swap discovery [Re: RV2] #17097
08/16/05 10:16 PM
08/16/05 10:16 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
more
Re: A body engine swap discovery [Re: RV2] #17098
08/16/05 10:23 PM
08/16/05 10:23 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
im not an a body guy but try mocking it up complete with a d shaft you may find offset or driveline angles are wrong! also get out your trusty torpedo level and see if that blocks tilted to the side at all...but anything is possible after all i see people selling big block b and e body k frames all the time so you can switch from a small block!!!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: A body engine swap discovery [Re: RV2] #17099
08/16/05 10:24 PM
08/16/05 10:24 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
another
Re: A body engine swap discovery [Re: RV2] #17100
08/16/05 10:27 PM
08/16/05 10:27 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
As soon as the complete engine is in I will post pics, anybody else have an opinion on this.
Re: A body engine swap discovery [Re: RV2] #17101
08/17/05 10:06 AM
08/17/05 10:06 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
BTT pretty interesting.....
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: A body engine swap discovery [Re: BBR] #17102
08/17/05 10:16 AM
08/17/05 10:16 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
YOU DA MAN!
seriously..keep us informed!
Re: A body engine swap discovery [Re: DJVCuda] #17103
08/17/05 12:53 PM
08/17/05 12:53 PM
near Alexandria, VA
Gas_Bandit Offline
Gas_Bandit  Offline
near Alexandria, VA
I don't understand the fascination with trying to use the wrong K frame. They aren't that hard to find.
2003 Mercury Marauder, 34k miles, 3.73s and custom flash tuned
1981 Camaro, 350 w/ Holley Stealth Ram MPEFI, Sportsman heads, roller cam, self-burned chips, wideband O2
1983 Firebird TA
1993 Saturn SL2 83k
Re: A body engine swap discovery [Re: Gas_Bandit] #17104
08/17/05 01:44 PM
08/17/05 01:44 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
First and foremost, the allure is to use the stuff you already have vs. finding a different K member and swapping it in. Not everybody wants to jack around with swapping a K if they don't have to.
Makes me wonder if that's how they used to put a SB in a D100 since they came with /6's and SB's. Or do pickups use different K's for /6 7 V8?
RMRW 2018
RMRW 2020
Re: A body engine swap discovery [Re: BBR] #17105
08/17/05 01:55 PM
08/17/05 01:55 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
I've seen a couple of cars done like that and it works. I agree with 349 MagnumRT too, its about using what you have not how much you can spend. Its ALOT cheaper to find a mount that will work than it is to find and hang the correct k-frame. I found out a month or 2 ago that with the 70's style 318 brackets you can use the rubbers from an 88 Supra and it will drop into a 64/65/66 a-body perfect. Didnt cost me a penny to put it in my buddies Dart because I have a blown up Supra engine in the shop and looked at the mounts and . Cheap new discoveries are awesome when they work.
Tim
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: A body engine swap discovery [Re: 70dart360] #17106
08/17/05 07:40 PM
08/17/05 07:40 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Plus it beats paying a $150 to schumaker for the conversion mounts.
Re: A body engine swap discovery [Re: RV2] #17107
08/17/05 07:47 PM
08/17/05 07:47 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Good job, reminds me of how we used to do it. Good old hot rodding at its finest!!
Re: A body engine swap discovery [Re: 69DartGT] #17108
08/17/05 09:03 PM
08/17/05 09:03 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Cool! A lot of people's idea of building a Hot Rod is picking up the phone and ordering the parts, congrats on using the brain cells. Of course this may not be matching #'s!
Sheldon
Re: A body engine swap discovery [Re: RUNCHARGER] #17109
08/17/05 10:45 PM
08/17/05 10:45 PM
Lees Summit, MO
BrianT Offline
BrianT  Offline
Lees Summit, MO
Freakin hilarious!!
That looks like the way my 340 is mounted. It was originally a /6, and a previous owner swapped in a 340. I wondered if it was a Shumaker mount or what, but it looks very similar to what you have there.
1970 Duster 340 clone
Re: A body engine swap discovery [Re: RV2] #17110
08/17/05 11:10 PM
08/17/05 11:10 PM
Rome, PA
Ryan_340 Offline
Ryan_340  Offline
Rome, PA
1972 Power Wagon W100 1973 Power Wagon W200 1971 Duster 1972 Dart Swinger 3-1972 Demons
Re: A body engine swap discovery [Re: 70dart360] #17111
08/18/05 12:39 AM
08/18/05 12:39 AM
MNobody Offline
MNobody  Offline
using toyota parts on a dodge? that's just wrong lol.
Re: A body engine swap discovery [Re: MNobody] #17112
08/18/05 04:52 AM
08/18/05 04:52 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Why? Old Dodges become new Toyotas all the time. I think it's more like "reclaiming"!
How did we get to where it became "uncool" to actually be innovative to solve a problem as opposed to "picking up the phone".
BTW, why is the Trans-Dapt SB-/6 K-member mount kit so much cheaper than Schumacker?
2 Demons...no, not my kids!
Re: A body engine swap discovery [Re: MNobody] #17113
08/18/05 08:18 AM
08/18/05 08:18 AM
Butler, PA
romanucci Offline
romanucci  Offline
Butler, PA
My old Dodge became a Mercedes a few years ago.
Re: A body engine swap discovery [Re: RV2] #17114
08/19/05 11:23 PM
08/19/05 11:23 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
It worked! the engine and trans are in, I finished up late so I did not get any pics, but in a day or two I will post several pics.
Page 1 of 3 1 2 3
