Re: 2004 Ram 2500 4x4 Hemi Exhaust Upgrade MPG?
[Re: 360view]
#1709779
12/12/14 03:53 PM
12/12/14 03:53 PM
Posts: 524 Mesa, AZ
Bill_T
Mesa, AZ
With all due respect, I am not convinced you will see 17 mpg out of a 04-08 3/4 ton 4WD Hemi even under your testing conditions, at least not with the 545RFE. There are a small number of MT trucks out there that might do it, but I still doubt it. And if I was to run that test, I would put a full 80 psi in the tires.... I agree that exhaust changes don't make much of a difference. Maybe with the full JBA set up, but the cost would swallow the increased mileage savings such that I doubt you would reach a positive ROI. I have the cat back set up on my 05 QC 4WD Hemi. It is lighter and sounds cool, but that is about it. The only thing that seems legitimately reported to increase mileage are the hub conversion kits - spyntec, dyna-trac, etc. Again, the cost will far exceed the savings, but there are some other benefits. I am looking at these now.
[Re: Bill_T]
#1709781
12/12/14 05:25 PM
12/12/14 05:25 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
I did the locking hub conversion on my 06 2500 QC Cummins truck and only got about 0.8 improvement at best. Not something I'd spend over $2K on again.
[Re: Guitar Jones]
#1709782
12/12/14 05:41 PM
12/12/14 05:41 PM
DaytonaTurbo
Manitoba, Canada
Thanks for the heads up. I read a few posts online buy guys crowing about an unrealistic sounding 3-4 mpg improvement!
[Re: A1OO]
#1709783
12/12/14 06:27 PM
12/12/14 06:27 PM
Posts: 4,255 Canada
WO23Coronet
Canada
I put a Flowmaster cat back on my 05 1500 HEMI quad 4x4, replaced the awful factory y pipe with a Magnaflow one and put on EBay Chinese shorty headers and got a nice performance boost. I never tested mileage but I didn't notice any obvious difference. These things cruise at 1700 RPM and probably only 25-30% throttle opening, I don't think you'll find much of a benefit mileage wise, BUT it's definitely worth the performance increase (0-60 in the mid-high 7's with mods, vs low to mid 8's stock), and I don't even have a tune yet. Honestly, if I had to do it again, I'd replace the factory muffler (the stock pipe is 3-3 1/2") and do headers and a y pipe. I read on a Ram forum someone dyno tested the y pipe mod and it alone was worth 8 hp (Did I mention the factory one is horrible?). The factory Y pipe on the new rams is even worse, I checked out a 2015 Ram 2500 Power Wagon and the one pipe going in is basically flat.
[Re: WO23Coronet]
#1709784
12/12/14 07:30 PM
12/12/14 07:30 PM
Posts: 524 Mesa, AZ
Bill_T
Mesa, AZ
Good point about the y-pipe. It is ridiculous. Crushes the pipes in half (picture).
At Guitar - when you are only getting 12mpg, that .8 is still almost a 7% improvement. I think the passenger unit bearing on mine might be crapping out anyway. outside of tire on that side is wearing....
There are o2 sensors after the cats. Remove them and it will throw codes. I am not convinced you will see a mileage increase either.
Header choice on the 2500s is pretty limited.
[Re: Bill_T]
#1709787
12/13/14 02:47 PM
12/13/14 02:47 PM
Posts: 4,255 Canada
WO23Coronet
Canada
Yeah headers choice is limited for the 2500's. I bought the Chinese headers because most shorties say they won't fit 1500 4x4's, only 2wd's. I couldn't figure out why because I think they use the same front ends (2wd vs 4wd) ie: spindles, control arms etc. Even the headers I bought weren't supposed to fit my truck but no one could tell me why. I put them on anyway and all I had to do was dent one tube on the passenger side where it hit the motor mount. I also had to shorten what looks like an anti loosening tab on one of the nuts on the upper control arm on the passenger side, it still works I just had to shorten it. The Ebay headers were under $200.
[Re: A1OO]
#1709790
01/14/15 08:03 AM
01/14/15 08:03 AM
Posts: 27,728 places
79powerwagon
places
There is only one way to get better fuel mileage from any 3/4 ton 4x4 truck with big tires- don't start it up. I'll never understand why so many people insist on owning these things (of all makes, not just Dodge) and then complain about fuel economy. What were you thinking when you bought it? If you need a truck for a daily driver, you will have significantly higher gas expenses than if you do not. If you need better fuel economy, you will be significantly limited in what you can tow and haul. Always, and without exception. Decide what you need for most of your use, and compromise accordingly.
[Re: A1OO]
#1709792
01/15/15 03:07 PM
01/15/15 03:07 PM
Posts: 1,106 Northeast
VincentVega
Northeast
If you want a point of comparison, this is my truck:
2005 hemi 1500 4x4 short bed standard cab. short, but heavy
3.92 rear end, with the 20" wheels. 275/60 R20 I think they are. pretty tall. not huge
With a mix of city and highway driving, the vehicle has a lifetime mpg average of 14.4 according to the computer. so I wouldn't expect higher than 14 with a 2500
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: VincentVega]
#1709793
01/15/15 05:54 PM
01/15/15 05:54 PM
Posts: 4,255 Canada
WO23Coronet
Canada
I have the exact same truck and that's about what I get. I've gotten 20 on the highway but everything was perfect, 17 is more realistic. Tire tread design and compound play a huge role in mileage, when its time for tires on your truck put some highway tread/hard compound tires on it (if it's practical)
[Re: WO23Coronet]
#1709794
01/15/15 08:11 PM
01/15/15 08:11 PM
VincentVega
Northeast
I put 17" steel rims and snow tires on mine and it scares the hell out of me to drive. like piloting a dingy in a hurricane with that hard compound I will say this. even with the big stock wheels aluminum/flower petal wheels, on a cool autumn night, it will lay a serious patch without torque braking. And that's with limited slip diff. I was impressed by that.
