Schumacher 5.7/6.1 Gen 3 to BEC Mounts #1709580
12/11/14 09:36 PM
12/11/14 09:36 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Schumacher is making Gen 3 mounts for B,E & C bodies. I do not know if they fit A bodies?
you have to get in touch with them & ask
http://www.engine-swaps.com/
Maybe a better alternative to the TTI mounts?
here are some prototype pics. The ones I'm getting are powdercoated
Photobucket is acting stupid again so you have to click on the link to see the pics
[IMG]http://i101.photobucket.com/albums/m69/arielrylis/BEC5761_zpsr9p5fhrn.jpeg[/IMG]
[IMG]http://i101.photobucket.com/albums/m69/arielrylis/DSCF1219_zpsr6173gri.jpeg[/IMG]
[IMG]http://i101.photobucket.com/albums/m69/arielrylis/DSCF1218_zpsyv3yfexq.jpeg[/IMG]
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: RylisPro] #1709581
12/12/14 02:07 AM
12/12/14 02:07 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I had no problem with my TTI mounts. Good to see an alternative.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: RylisPro] #1709582
12/12/14 10:03 AM
12/12/14 10:03 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Nice.
I've read that buying the same mounts as the headers you are using isn't a bad idea...but I've seen some worthy TTI mount with TTI header header "clearancing" as well. I was considering buying TTI and either using them as a base for modification, or maybe the headers would fit reasonably with them.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: GoodysGotaCuda] #1709583
12/12/14 11:22 AM
12/12/14 11:22 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
They cost a bit more than TTI mounts but I'll take a chance on them. I just really didn't want to give TTI anymore money since we will probably need to make their headers fit.
Schumacher is a good company and I have one of their torque straps for my 340.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: RylisPro] #1709584
12/12/14 11:34 AM
12/12/14 11:34 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Did Schumacher make them to work specifically with your TTI headers? I'm assuming not?
You've got no room to complain if you have TTI header issues and you don't use TTI mounts.
Alex's TTI headers and mounts fit fine with the normal mods, other than the AC compressor/ header interference.
A body guys have the tight fit. Not the B and E body guys.
If you do buy Schumacher, I'll be curious to hear how they fit.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: Uhcoog1] #1709585
12/12/14 12:18 PM
12/12/14 12:18 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Schumacher stated to go ahead and use the TTI headers. I was planning to go with TTI mounts initially,
but I'm going to give these a try and report back
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: RylisPro] #1709586
12/18/14 07:12 PM
12/18/14 07:12 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: RylisPro] #1709587
12/18/14 07:51 PM
12/18/14 07:51 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
So those don't allow the oil filter in the stock location either? How about with an angle adapter?
Mopar to the bone!!!
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: 72Swinger] #1709588
12/18/14 08:14 PM
12/18/14 08:14 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Mr. Schumacher said that you can't use the 45 degree adapter.
That's why I'm trying to find a block off plate that is aluminum and less expensive than TTI's
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: RylisPro] #1709589
12/18/14 08:24 PM
12/18/14 08:24 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Just get a remote adapter from Derale, block off plates are almost a for sure leak. This one exits out the bottom but they make them exit out the front too.
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: 72Swinger] #1709590
12/18/14 09:46 PM
12/18/14 09:46 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Yeah I am hesitant to get a block off plate especially one from TTI.
Do you have a part number for that Derale unit?
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: RylisPro] #1709591
12/18/14 09:57 PM
12/18/14 09:57 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: 72Swinger] #1709592
12/18/14 10:09 PM
12/18/14 10:09 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Awesome! I'm going to get the one that you have
it looks like a nicer piece and I am goin to use -10 AN fittings
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: RylisPro] #1709593
12/18/14 10:12 PM
12/18/14 10:12 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Well, brace yourself when you get the o-ring swivel fittings, $$ouch.
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: 72Swinger] #1709594
12/18/14 10:31 PM
12/18/14 10:31 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
It is what it is. Quality fittings like XRP are not cheap.
I would pay any price for no leaks
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: RylisPro] #1709595
12/19/14 02:14 AM
12/19/14 02:14 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Is -10 big enough?
I've seen the carnage that came from another shop into my builder's place. Twin 540 BBC from an off shore type boat. Blew up 2 of them and then blew up another one and fatally wounded the other before he changed builders. $30k EACH.
They were running -10 hydraulic lines to remote filters and the cranks were blue.
My guy said that hydraulic line is actually smaller than 5/8" that a -10 is supposed to be compared to say Aeroquip and he recommends -12 minimum. He built the guy 2 more engines and put bigger oil lines on, no more spun bearings.
Every drop of oil the engine sees has to first go thru that hose to the filter and then back to the engine so as far as he's concerned he would run a -16 if it will fit.
Kevin
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: Twostick] #1709596
12/19/14 02:31 AM
12/19/14 02:31 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Im not gonna use hydraulic line that's for sure. My oil is going to go through a filter then a thermostat then a cooler and then to the engine.
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: Twostick] #1709597
12/19/14 02:58 AM
12/19/14 02:58 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Is -10 big enough?
The ports on the side of the block are 3/8 npt which is closest to a -8AN so the restriction will be there and the filter adapter ports which are -10 AN.
Regardless, If I have to go -12AN or even -16AN, it won't be a problem
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: RylisPro] #1709598
12/19/14 04:21 AM
12/19/14 04:21 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You can use the top port for the accumulator and the bottom can be for a pressure sensor. That's my plan anyway. Oil temp with come bung in pan. And if I data oil pressure it will come filter adapter.
Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts [Re: 72Swinger] #1709599
12/19/14 12:25 PM
12/19/14 12:25 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
-10 even though technically 5/8 line has about 1/2 id. I would consider using -12 minimum
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
