Page 5 of 6 1 2 3 4 5 6
Re: How much to build 440? [Re: moper] #1708513
12/26/14 03:55 PM
12/26/14 03:55 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
.....You can get beyond 400hp very easilly without gtting into anything beyond the cam, and that includes the factory intake and carb.
I'd like to see that.
Give me a decent running 440, any year, all stock. You pay parts and the dyno test after. I'll document anything I do. It's that simple.
And how bout if it doesn't hit 400 hp you pay for the dyno pulls.
This is not for my benefit, and I'm investing my time and others would be capitalizing on my experience. It's unfortunate others can't get good results but sometimes lack of skill and/or ignorance takes a toll.
Your comments are interesting. So you would rather have someone pay for the parts and dyno time, and you supply all of the labor, to tell us the results for something you already know, as to not give away your secret intellectual property?
You first state that +400 hp is very easy (emphasis added) with stock intake and carb, 8:1 CR compression 440 with someone's rebuilt 906 heads. Further implying it is simply a matter of a cam, ignition and tuning.
The delivery of your comments are so confident and absolute, why would you even suggest buying parts and conducting dyno runs? Why don't you instead just share with us the details on how to do it along with the objective evidence, preferably track data.
I'm all in agreement about your "tuning" comments.
I've spent considerable time and track testing on a very similar example to this. It became a respectably fast car for what it was and an absolute blast to drive in the street. It was no where near 400 hp. Open headers (are headers included in your <$1200?) and a bigger cam would have helped, but would likely not get us to 400hp.
So, I'm genuinely interested in how you have achieved over 400 hp with the described limitations, for us ignorant/lack of skill folks.
Re: How much to build 440? [Re: BSB67] #1708514
12/27/14 02:15 AM
12/27/14 02:15 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Maybe this will give you a few ideas. We invited the neighbors over for a 'dyno day' at the shop and made a few changes to a 7.5:1 compression 440 over about eight hours and made a dyno pull after each change. It wasn't designed to be a perfect combination, we started with stock 906 heads and used parts we had laying around.
Low compression 440 dyno test.
400 seems pretty easy as I suspected. I would think it might have done even better with the 528 solid.
Kevin
Re: How much to build 440? [Re: Twostick] #1708515
12/27/14 10:16 AM
12/27/14 10:16 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What parts? Stock intake and stock carb, right? That was the criteria claimed.
Re: How much to build 440? [Re: Twostick] #1708516
12/27/14 12:30 PM
12/27/14 12:30 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I did a ring and bearing and head refresh on a '71 440 shortblock with 452 heads. CR ended up being 9.5:1.
With a.528 MP solid, headers, recurved dist. and a 750 3310 Holley being the only mods, it did a 13.50@104mph. No traction and horrible 60ft. times. With slicks and decent springs it would've easily hit 12's. It was a torque monster on the street! 2500 stall converter and 3.23 highway gears. The .528 barely had a lope once warmed up! 320 HP at the rear wheels. I really feel the stock intake was a major cork in the combination.
My most recent build is kinda the opposite as I used a '75 shortblock that only needed rings and bearings as well. It was lower compression but I used 906 heads and a .484 MP hydraulic. It feels stronger than the previous motor but I haven't had it to the track. It too still has the cast iron lump of a dual plane but will be getting my Holley Street Dominator installed soon. May do a back to back comparison.
The recurve and degreeing in the cam is where most people miss the tuneup. Mr. Gasket #925B lightweight springs in a Chrysler electronic distributor feeding an MSD 6AL box is a great ignition!
Using the Holley 750 3310, I used the lightest weight spring in the vacuum secondaries as well and never had it bog. I have an 850 Demon that I'm going to try on the latest build.
Good flowing heads are KEY in making 440's run. The 906's have a slight flow advantage over all the other head castings. They wake up even the soggiest low comp. motors.
Re: How much to build 440? [Re: GY3] #1708517
12/27/14 02:16 PM
12/27/14 02:16 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
With a.528 MP solid, headers, recurved dist. and a 750 3310 Holley being the only mods, it did a [Email]13.50@104mph.[/Email] No traction and horrible 60ft. times. With slicks and decent springs it would've easily hit 12's. It was a torque monster on the street! 2500 stall converter and 3.23 highway gears. The .528 barely had a lope once warmed up! 320 HP at the rear wheels. I really feel the stock intake was a major cork in the combination.
Your compression was higher than ours, but this is where we ended up too, in both performance and conclusion. Getting the iron intake over 350 hp is the challenge, I think.
Re: How much to build 440? [Re: BSB67] #1708518
12/27/14 02:25 PM
12/27/14 02:25 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I'm really curious to see what the Street Dominator and 850 carb does...
Oh yeah, the latest 440 ran me about $2,600 to build with the heads being the major expense. It does have stuff that wasn't necessary like a 7 quart deep sump and aluminum water pump and housing. Truly one of the nicest original block/crank combo's I've encountered. I paid $375 for the core motor.
Re: How much to build 440? [Re: GY3] #1708519
12/28/14 02:20 AM
12/28/14 02:20 AM
MD
p d'ro Offline
p d'ro  Offline
MD
With the 528 cam motor, did it have a stock intake? I don't doubt you, just surprised that such little mod would make so much power. Stock was 375 crank hp on my 67 440to get that much reap would be tough.
Re: How much to build 440? [Re: p d'ro] #1708520
12/28/14 11:04 AM
12/28/14 11:04 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
The .528 cammed motor used a stock '71 intake.
906 heads would've helped as would have a better intake.
Low compression isn't all that horrible as some people would have you believe. A good flowing set of heads is critical to making good power.
Re: How much to build 440? [Re: moper] #1708521
12/28/14 10:01 PM
12/28/14 10:01 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Sorry for the delay, I usaully respond quicker when being insulted but I was off galavanting with my family so not really on the computer. YOUR statement was 400 easily without gettting into anything beyond the cam, my statement was put your money where your experience is. You said nothing of heads or distributor work or even carb work, you said nothing beyong the cam, if you are so sure you can do it then agreeing to pay for the pulls if it doesn't yeild 400+ would just be academic. I believe though my experience, maybe worse maybe better, that is a tall claim.How can I loose, if I delivered to you a solid smogger and I walk away with a 400+ HP engine for the cost of a cam swap & set up and some dyno time, I'd be all in. If you fail to deliver I am still out time and money to get you the engine. I just think you made a statement that cant be proven true, even on paper.
I'm running a truck and trailer up to PA in the next week or so with enough extra room for an engine, should I bring it to you?
Careful, your character's showing!
Re: How much to build 440? [Re: mopar346] #1708522
12/29/14 02:34 PM
12/29/14 02:34 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
I believe the secret involves porting and polishing the intake manifold bolt holes, tying a knot in the PCV hose, and swapping the carb mixture screws side to side. And putting tiny lifejackets on the carb floats. Each of these mods is covered in my new tuning book "Go Fast or Die Trying" available here for $10.
Re: How much to build 440? [Re: Vert] #1708523
12/29/14 03:08 PM
12/29/14 03:08 PM
mopar346 Offline
mopar346  Offline
Although I am familiar with those mods and their effectiveness, they are beyond the cam, so not eligible or needed by his description.
Re: How much to build 440? [Re: mopar346] #1708524
12/29/14 05:02 PM
12/29/14 05:02 PM
USA
b54406barrel Offline
USA
Thread's still going? The correct answer is 'Too much'. Build a 600 hp chevy for what it cost to build a 400 hp mopar.
Re: How much to build 440? [Re: b54406barrel] #1708525
03/28/15 08:59 AM
03/28/15 08:59 AM
M.A.
Fern Offline OP
Fern  Offline OP
M.A.
Sorry for bringing up an old thread, but
I've decided to put the hughes whiplash cam
lifters, Rpm intake.
Keep the 906 heads.
MSD 6al
I would like to keep the stock exhaust logs since I dont care for headers.
If I dont change to headers, will it make a huge difference?
The dyno's I have found dont test with headers, so I have no idea how much HP would be lost with the logs.
Re: How much to build 440? [Re: Fern] #1708526
03/28/15 11:18 AM
03/28/15 11:18 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I would guess around 30. It will be significant.
Re: How much to build 440? [Re: GY3] #1708527
03/28/15 11:31 AM
03/28/15 11:31 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I had a low compression 440 in my GTX for a bit.
Stock heads, 509 cam, headers, TM7 intake with a TQ and a manual trans and it made several 12.6 passes on slicks without breaking a sweat.
I'd not worry about the shortblock too much. Pop in a better cam, find an aluminum intake like a Performer RPM or one of the DP4B? dual planes with a 750-850 cfm carb, headers mandatory and recurve the distributor and go have fun on pump swill gas.
"I think its got a hemi"
Re: How much to build 440? [Re: Fern] #1708528
03/28/15 11:35 AM
03/28/15 11:35 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I have seen tests on small blocks back to back, as much as 40 hp left on the table. And that was at a 300 hp level.
30hp minimum would the floor but with a 400hp motor I think it would be higher than 40 hp.
Re: How much to build 440? [Re: BSB67] #1708529
03/28/15 11:50 AM
03/28/15 11:50 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
professional mopar engine builder in WNY area wll rebuild your existing motor with all new internals and head job for 3500. Choose from a good selection of cams and the motor will produce well over 440hp on pump gas
Re: How much to build 440? [Re: Fern] #1708530
03/28/15 12:06 PM
03/28/15 12:06 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Are they "logs" as in lo-perf or the HP manifolds.
If truly the logs, I would try a set of headers with the thicker 3/8" flanges. Or not waste my time. Too much left on the table.
Re: How much to build 440? [Re: Dean_Kuzluzski] #1708531
03/28/15 12:30 PM
03/28/15 12:30 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Did you see the dyno testing done on the 440 mentioned in this thread? I went through the 6 pages and read everything.
Going from logs to HP manifolds was of little beneficent at the hp level they were at (stock intake, cam and carb I think) and it looked like over 3500 RPM the manifolds were a choke point.
Headers all the way.
I have manifolds on my Duster that are going in the bin, the fact I'm leaving at least 40 hp on the table irks me badly.
Re: How much to build 440? [Re: gdonovan] #1708532
03/28/15 01:02 PM
03/28/15 01:02 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If you aren't going to use headers then the cam you want is the MP528 solid. AndyF tested a bunch and with manifolds it did the best by a good margin.
Kevin
