Page 3 of 3 1 2 3
Re: aluminum sealing washers 4 external oil pan lines? [Re: Jerry] #1707561
12/10/14 07:07 PM
12/10/14 07:07 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
its a little hard to see as the pic is a little blurry but on the side away from the fitting there is a groove for an oring. the o ring seals against the oil pan wall. on the fitting side of the washer there is a special port groove for use with the o ring on AN-12 style port fittings, which is what all the earls and aeroquip fittings are designed around.
these could even be used on both sides of the pan to seal a bulk head extra assurance. so you'd have fitting, washer, oil pan wall, washer and then lock nut. if its still unclear i'll post up a drawing later.
Re: aluminum sealing washers 4 external oil pan lines? [Re: John_Kunkel] #1707562
12/13/14 04:39 AM
12/13/14 04:39 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Parker Stat-O-Seals http://www.allsealsinc.com/statoseals.pdf
These can be bought thru McMastercarr.com
Not cheap but they work great. Beep
Re: aluminum sealing washers 4 external oil pan lines? [Re: pittsburghracer] #1707563
12/13/14 09:16 AM
12/13/14 09:16 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
[/quote
Unfortunately we could never get these to work, they never fit flush due to the strengthening ribs on the pan. Pan is a dual line Milodon Super stock style with hole for the tie rod BTW. They may work on others of course.
Used dowty washers in the end
Re: aluminum sealing washers 4 external oil pan lines? [Re: Bigbeep] #1707564
12/13/14 02:55 PM
12/13/14 02:55 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Find an industrial supplier. Looked at Summit's pricing and their pricing is almost criminal.
P/N: 600-0101-3/4 or NAS1523-12 should be able to find for about $2.50ea or less. They are the seals designed for bulkhead applications.
The metal cup and o-ring shown above already made by Parker as the 800 series Lock-O-Seal. Made for applications that allow trying/changing o-ring compounds.
Check hoseandfittings.com for the 600 series (thats where I got $2 price from) or aerospace parts dist for the NAS series.
Page 3 of 3 1 2 3
