Valve Cover spacers Area 51 Group Anyone got Contact #?
#1706198
12/03/14 07:09 PM
12/03/14 07:09 PM
Posts: 1,347 Wahoo Nebr
vette1986
Wahoo Nebr
Hello I am needing a set of valve cover spacers for my 440 so I can run the stock valve covers with my roller rockers. I have clearanced them from the inside and they work with double gaskets but I am chasing leaks around and it is killing me! So I did a post to ask about these spacers that used to be posted on moparts under the engine for sale section and I got the Name area 51 group and the link to them: http://www.area51groupllc.com/product_info.php/cPath/26/products_id/44But the cart does not work on the site, the contact us does not work and there is no # to contact them. So my guess is they are MIA but I know the person that had listed them on here before was a moparts member. Does anyone now who it was or where I can get a set of 3/16 or 1/4 spacers?? Any help would be great. Thanks
1969.5 A12 Bee EV2 1971 Charger RT 1973 Duster tubbed 500 low deck 10.90 monster 3 440 polara vert projects
Re: Valve Cover spacers Area 51 Group Anyone got Contact #?
[Re: JohnRR]
#1706200
12/03/14 07:55 PM
12/03/14 07:55 PM
vette1986
Wahoo Nebr
To a fellow A12 guy you want to sell me the set you have??
[Re: roadhazard]
#1706203
12/04/14 02:02 PM
12/04/14 02:02 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
IIRC those spacers are not being produced any more.
I may be wrong but think I remember him posting that at some point on the board
I'm guessing they weren't a hot seller , I'm running sharps under 69 sheetmetal covers wit ha 550ish cam , I doubt I'm not going to need them. I was going to see if I could get them drawn up and make a set on the CNC at work
[Re: Jerry]
#1706209
12/05/14 12:40 PM
12/05/14 12:40 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I'd be be down for a big block set.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: pittsburghracer]
#1706213
12/05/14 02:44 PM
12/05/14 02:44 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
They should be an easy make, Take a nice rigid gasket, trace onto 3/16 aluminum, and start cutting. Or if you have a mill, or access to one, start milling away. Mike, I can grab some aluminum and make a set for ya. will be kinda fun, and I have the tools to do it.
[Re: Moparnut426]
#1706214
12/05/14 06:24 PM
12/05/14 06:24 PM
vette1986
Wahoo Nebr
Kasey, Yeah man make me a set as I was going to have you put them on this winter anyway when I bring the RT up as I finally have a dash pad on its way, a new speedo, and was going to have you drop off the manifolds again and hit them with some Eastwood.
[Re: Moparnut426]
#1706215
12/05/14 06:48 PM
12/05/14 06:48 PM
JohnRR
U.S.S.A.
Milling them by hand is not going to be as easy as you think , but have at it .
[Re: Jerry]
#1706216
12/05/14 09:26 PM
12/05/14 09:26 PM
Posts: 6,445 Missouri
68KillerBee
Missouri
pricing would be $85.00 per pair at .25 thick plus shipping. I have the drawings for both big blocks and small blocks so both engines are available.
I would be in most likely. Still don't know what rockers I will be using in my build, but I'm banking on them not fitting the stock valve covers.
[Re: ScottSmith_Harms]
#1706220
12/07/14 02:22 PM
12/07/14 02:22 PM
JohnRR
U.S.S.A.
I bought and used a set of Area51's for a small block. They worked very well, fit nice and gave the clearance I needed. If I were to change anything it would be to have an improved/smoother surface on the edges, the cutting left them a bit rough on the side surfaces. Maybe water jet cutting would have solved this. Overall a great product and the price seemed fair to me.
He did cut them on a water jet , that is why they are like that , Doing them on a CNC would give a smooth surface.
[Re: JohnRR]
#1706221
12/09/14 12:17 AM
12/09/14 12:17 AM
Posts: 6,988 Warren, MI
Jerry
Warren, MI
I found all the files to make the valve cover spacers. pm me here or drop me an email to jerry@sdconcepts.com and I can get these going. big block or small block .25 thick 85.00/pair
