'99 Ram "check gages" light ??? #1706065
12/02/14 08:24 PM
12/02/14 08:24 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I have a '99 Ram 5.2l. The "check gages" light came on and I noticed the voltmeter was around 12v. I made a stop and turned the engine off. When I started it up the light was out and the gauge was normal at 14v. After a while it came back on and the meter dropped to 12v again.
Would this indicate a bad battery or bad alternator ??
Re: '99 Ram "check gages" light ??? [Re: Stanton] #1706066
12/02/14 10:35 PM
12/02/14 10:35 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You should probably check it when it does it, with a voltmeter at the battery. It may be lying about the no charging. My 01 durango did that in pouring rain on a trip to the Nats from Chi. It kept charging the whole time. I figured some lame connection someplace that was compromised by rainwater. Next time I started it, all was well, and it never did it again for years.
Re: '99 Ram "check gages" light ??? [Re: buildanother] #1706067
12/02/14 11:30 PM
12/02/14 11:30 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
It was the batteries in my 04 2500 Ram when it happened to me last year.
