POWER STEERING BRACKETS #1705320
12/01/14 01:36 AM
12/01/14 01:36 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Pulled a slant six from a 80 150 2wd. Going with a 340 back in, are power steering pump brackets the same or different between the 2 engines.
Re: POWER STEERING BRACKETS [Re: rickb67] #1705321
12/01/14 06:06 PM
12/01/14 06:06 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
not sure, but if you need a set of smallblock brackets, let me know. i have a set just collecting dust.
Re: POWER STEERING BRACKETS [Re: Golden-Arm] #1705322
12/01/14 09:08 PM
12/01/14 09:08 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I highly doubt they would be the same. Everything on the slanty is to the center or passenger side 1/2 of the vehicle where a 318/340 would be towards the driver side of center. Gene
Re: POWER STEERING BRACKETS [Re: Golden-Arm] #1705323
12/02/14 03:45 AM
12/02/14 03:45 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
thanks will let you know
