Re: questions about hanging TTI exhaust, tailpipe hangers?
[Re: Hemi ragtop]
#1704709
11/30/14 12:21 AM
11/30/14 12:21 AM
I have an accurate exhaust left hager bracket made of stainless with hardware I would sell you. Plus I have an original bracket that needs to be blasted I would sell you.
[Re: CR8CRSHR]
#1704711
11/30/14 09:59 PM
11/30/14 09:59 PM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
Thanks for the responses. I worked for a day and a half, just to find that I was invoiced for a headpipe to clear the GV unit, only to find that the "h" pipe is right on the GV sump! My arms, to the tips of my fingers look like I took a close range blast from a 20 ga. with birdshot! So, remember the old days? I have hung more than one muffler on baler wire! I test drove the car and the unit is GREAT! At flat and level cruise @ 70 mph the tack is at 2,200 rpm vs. 2,800. Just right as the engine hits a "sweet" spot @2,500 rpm. (timing Is full in @ 2,500). I can finally can take long distance cruises, maybe to the Goodguys in Nashville next year, etc. Pics inclosed. First, I mounted the switch and "controller" on the small trim piece just under the steering column. Drilled a hole in the center to run the wires through.
