#3438348 440 6-pak distributor, has ne1 ever had one? #1704283
11/28/14 12:01 PM
11/28/14 12:01 PM
usa
W
whomper1 Offline OP
whomper1  Offline OP
W
usa
I've been looking for that distributor for years and 1'm starting to wonder it it ever existed?
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: whomper1] #1704284
11/28/14 04:59 PM
11/28/14 04:59 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
Try Tony's Parts
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: 44D6PAKCUDA] #1704285
11/28/14 10:02 PM
11/28/14 10:02 PM
Alabama
BigMoneyLewis Offline
Alabama
They show up on e-bay pretty regular .
Their is a 4-speed T/A dist on right now , for example (I didn't spot an auto dist. at the moment but I have seen a dozen T/A dual points on there in the last few months)..
Just use "Mopar dual point" as your search words and do that search about every 3 days . One will come up sooner or latter .
Also, their has been at least one I saw here in Moparts classifieds not that long ago.
Greg
gregward@mchsi.com phone 256-852-0955
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: whomper1] #1704286
11/28/14 11:40 PM
11/28/14 11:40 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
If you want that specific distributor (#3438348), it is probably hard to find because it was used only on '70 440-6 4spd cars built after Jan 1/70. There was an NOS one for '70 440-6 4spd cars built before Jan 1/70 on ebay a few weeks ago that sold for $500.
http://www.ebay.com/itm/1970-MOPAR-Dual-...=p2047675.l2557
If one for a different year/transmission 440-6 is acceptable, you may have better luck finding one.
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: moparfan53] #1704287
11/29/14 03:33 AM
11/29/14 03:33 AM
Alabama
Alabama
Ooops, just ignore my above message. For some reason I thought you needed one for a 340+6 . I mis-read, and I didn't take the time to look up the number .
But, the same holds true ..e-bay is your best bet .
Their are usually at least 25-50 Mopar Prestolite dual points on e-bay at any given moment . I have bought big block A body , Hemi, 71 six pack prestolites all pretty easily myself ..never had to look more than a couple weeks to find the correct number I needed.
Greg
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: BigMoneyLewis] #1704288
11/29/14 04:40 AM
11/29/14 04:40 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Any one know why there was a Jan. change from one Distributor to another and what that change might of been.
1971 HEMI E BODY REGISTRY
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: hemicar1971] #1704289
11/29/14 12:11 PM
11/29/14 12:11 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I "had" a Prestolite dual point about five years ago with the spark retard vacuum advance that I changed,was an early 70's date code but don't remember the part number,only one I've ever seen.Still have what I took off.
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: 62maxwgn] #1704290
11/29/14 02:09 PM
11/29/14 02:09 PM
Sacramento,California
JRepucci Online content
JRepucci  Online Content
That vacuum advance would be from a 71 440-6 Prestolite
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: JRepucci] #1704291
11/29/14 02:20 PM
11/29/14 02:20 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Looks like you are correct Jason, the advance is a 1971. I wonder if the number is still on the Advance.
I asked in an earlier post why the change in 1970. How much money did Chrysler spend on the second distributor after only having this one in production for 6 months. Maybe they used a 440 DP from 1969 and just changed the advance and then got time to make one for 1970 only. I have an NOS early distributor for a 70 440-6 Man. I have one other I took out of a 1970 440 in the Seventies that I swamped in an aftermarket for the guy. I will see if I can find it and just what one of the 1970 440-6 distributors it is.
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: hemicar1971] #1704292
11/29/14 04:33 PM
11/29/14 04:33 PM
usa
W
whomper1 Offline OP
whomper1  Offline OP
W
usa
thanks for the help and input
tonys doesnt have one, nothing shows up on a google search
so, is this one of those parts that is listed in the # book but was never made?
does it show up on a build sheet?
you would think that someone here has had one and hopefully a picture of it
is there a known IBS # ???
i'm really starting to feel that this distributor was not made
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: hemicar1971] #1704293
11/30/14 11:45 AM
11/30/14 11:45 AM
NY
moparmatt0 Offline
moparmatt0  Offline
NY
Do you want to sell the early nos 440-6 manual dist I could use it for my Cuda.
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: hemicar1971] #1704294
11/30/14 03:12 PM
11/30/14 03:12 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Different parts for the early and late ones from the '70 parts book. Maybe emission related?
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: whomper1] #1704295
11/30/14 03:38 PM
11/30/14 03:38 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
IMO, it was made, because the cars were made. The only time I have seen part numbers in the book that were not made (AFAIK) are for the 1971 Challenger T/A, which did not make it to production.
AFAIK, distributors are not on broacast sheets. I suspect it is because the dist. was part of the engine assembly, which was shown.
I have to ask, what is an "IBS#"?
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: moparfan53] #1704296
11/30/14 03:42 PM
11/30/14 03:42 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
IBS/IBK is the first three digits of the Prestolite identification number.
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: 62maxwgn] #1704297
11/30/14 04:08 PM
11/30/14 04:08 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Ok, thanks. I went back and looked at the ebay one above. I see it is stamped on the bottom of the ID tag.
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: whomper1] #2260589
02/27/17 05:19 PM
02/27/17 05:19 PM
Arizona
AzMoparMike Offline
AzMoparMike  Offline
Arizona
Ive collected many parts over the years but don't have a 3438348 but I did find a 3438355 which is the replacement assembly without the rotor and cap so im sure they exist.
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: whomper1] #2260902
02/28/17 04:06 AM
02/28/17 04:06 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I think I have 348, I know I have a 349.
Try Tony's
Re: #3438348 440 6-pak distributor, has ne1 ever had one? [Re: hemicar1971] #2260948
02/28/17 11:17 AM
02/28/17 11:17 AM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
Based on the components/parts list for each distributor, it looks like the Chrysler engineers specified a change in the “SHAFT, Governor and Cam Drive”, and also the “CONTROL, Vacuum”. These two items are the main features of a distributor that alter the rate of both the mechanical and vacuum advance curves. They must have felt a new curve for both types of advance were needed to improve the engine function/performance/emissions, etc., and these are potentially a few reasons why the change happened mid-year.
One of the ways I’ve identified early and late assembly line distributors on 1970 models is by the vacuum advance. Early units had a “long snout” adjustable advances, and later units had the more familiar “canister” style advances. The advance on the distributor pictured by AzMoparMike is the later style.
