Re: Valvetrain weight and spring pressures
[Re: Hot 340]
#1703667
11/28/14 03:57 PM
11/28/14 03:57 PM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
Hypothetical question:
X motor, with proper X valvespring, with, say .080 wall pushrods, With ti retainers.
Then: change pushrods in above motor to .140 wall pushrods, steel retainers. Nothing else.
Does the motor use the same spring with the two changes? Do the pro builders weigh components or do they simply guess?
If anything, the steel retainer is most likely to change your spring requirement if it does at all.
Not sure what you mean by a pro builder, but if your entire valvetrain system as it is hasn't been tested on a Spintron, it's really a guess. Bouncing the valves on the seats is probably the biggest parts breaker, but there are places between opening and closing that will cause trouble as well.
[Re: Hot 340]
#1703668
11/28/14 05:01 PM
11/28/14 05:01 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
I had a pair of Smith Bros. pushrods fail(one broke in half in the middle after bending and took the other one out bending it also ) on a dyno test, it hurt the cam lobe and broke the top of the Crower solid roller lifter off I had ordered 3/8 diameter with .120 wall for a roller cam originally, I took the broken one back to Smith Bros and one of the shop employees made a comment that thier .083 wall 3/8 pushrods shoouldn't of failed that way They where not .120 wall like I had ask and paid for They replaced the two pushrods for no charge but didn't offer to help pay for the cam repair and lifters damaged. Smith Bros. was 5 miles awy from me back then, they have since moved thier shop 23 miles away now to Redmond OR. I fixed the motor and ordered a set of Manton Series # 3/8 diameter .120 wall thick pushrods of the exact same length and took them with me to the dyno, we made several pulls to warm the motor up with the Smith Bros. pushrods in it, changed the oil and filter. I checked the valve clearances and made several more pulls to make sure the motor was repeating. I changed the pushrods, no other changes, and that motor picked up 300 RPM to peak HP and 8 HP on that change Stiffer is better on pushrods when there are any doubts Years ago, circa 1968 or 1969, Don Prudhome(SP?) tested a set of tapered D&D pushrods in his old front engine top fuel dragster at Orange county dragstrip one Wednesady night, the motor picked up around 800 RPM and he had to lean the fuel system down around 20% was what was listed in the article that Hot Rod or Car Craft put out later about that test. The car picked up quite a bit also from that change, I don't remeber the exact amount but I'm thinking around .2+ ET and 2 to 3 MPH The RPM you shift at has a lot to do with what will work best for you also
[Re: Cab_Burge]
#1703669
11/28/14 06:15 PM
11/28/14 06:15 PM
Trend is toward stiffer pushrods ignoring weight there--I use titanium retainers on everything I can--over the years it has proven to be the easiest way to get better spring life, better rpm and more protection against loss of control--never race without them. On the dyno you find out pretty quick that engines love more spring pressure thus better control---big solids like the beloved .590 and Comp .650 always run better with more spring. My Nascar pal tells me they turn 10K rpm now but the valvetrain is so very light they do it with 125 seat and 300 plus open so...weight is everything! They are going roller next season so...I expect RPMs to climb up and up--I bet 11,000 is going to be the slow pokes and some will turn more--has to happen--it is the only logical place to find more HP. Mopars have always had the heavy valves--11/32 " in all the aftermarket heads helps a lot but then when you get Indy and Hemi size heads it is still trouble--the best running race stuff alwyas has titanium valves--you can Hear the diff on the dyno--every time!!! Average racer should not load the car on the trailer without titanium retainers in my book. Taller springs, bigger diameter are always better. Better control, better life, more RPM every time. I have never been able to see a loss from mechanical --like more pressure etc---the gains from better control always trump the mechanical myth in my experience.
[Re: dvw]
#1703670
11/28/14 10:55 PM
11/28/14 10:55 PM
Posts: 16,925 NC
440Jim
NC
For what it's worth I run 2.25 stainless in my -1 head. T&D paired rockers, Comp 892 tappets. Pushrods are 7/16" tapered .165" wall. I found a broken spring at Monster Mopar. It shattered the outer into 4 pieces.
What valve springs were you running? What cam lift and rocker ratio? What shift and finish line RPM?
I just started running the same rockers with 1.65 ratio, but with Ti retainers and the same lifters (pushrod oiling). My Manley springs are 300 seat/700 open. Gross lift is 0.777/0.774" (less after lash).
[Re: 440Jim]
#1703671
11/29/14 01:43 AM
11/29/14 01:43 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Look at what nascar runs for pushrods and that with tell you. I run 1/2 inch .165 wall pushrods in my motor.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 440Jim]
#1703672
11/29/14 01:55 AM
11/29/14 01:55 AM
Posts: 9,835 MI, usa
dvw
MI, usa
Ti retainers, Comp 996 springs in at 1.950". .470" lobe @ 1.7 for .799" before lash/deflection. I've been led to believe that H-11 tool steel springs are susceptible to stress failure. Shifts are at 6800, traps 7000-7100. Pac chrome silicon springs are in the future. My point was even with the loss of spring pressure the motor didn't slow down. I'm sure the tappets didn't like it. Though I saw no lash change even after another 30 passes. The tappets will go in for a refresh just to make sure, 183 passes. Doug
[Re: dvw]
#1703673
11/29/14 04:19 AM
11/29/14 04:19 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
What do people think of the tapered pushrods? Does the triangle shape actually improve stiffness in the pushrods? I am thinking of long ones like in a Hemi....Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1703674
11/29/14 04:29 AM
11/29/14 04:29 AM
Cab_Burge
[Re: astjp2]
#1703675
11/29/14 10:36 AM
11/29/14 10:36 AM
Jerry Kathe
The biggest bang for the buck in preventing deflection is diameter. Besides the obvious adapting size transition, location of the taper also diverts the stress concentration....the better that is engineered....the thinner the wall (lighter assembly) that can be used.
