Re: Why does tunnel ram work so good on BBmopar not oth
[Re: ScottSmith_Harms]
#170299
12/21/08 05:00 PM
12/21/08 05:00 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
My old DartSport had an M1 single plane and 1050 Dominator running in the 10 flat range with a best of 9.96 on a real cold day. I switched to an M1 low deck tunnel ram with 2 750 Quickfuel carbs and the car was a whole new animal. It started and idled better in any kind of weather as long as it was over 35 degrees. Ran consistant 9.90's with a best of 9.88. Footbraked to a 1.36 60 foot, this was an 11 to 1 compression 451 with the MP 590 purple shaft solid cam.
Re: Why does tunnel ram work so good on BBmopar not others?
[Re: quickd100]
#170302
12/22/08 11:11 AM
12/22/08 11:11 AM
Posts: 4,765 Holland MI Ottawa
2boltmain
Holland MI Ottawa
In the early 90s Edelbrock made a "Street" tunnel ram for mopar small block. It was not as tall as a Weiand or the early Edelbrock units. They only made them a few years.
Keep old mopars alive.
