Re: Any stock or stock eliminator racers here?????
[Re: GTX MATT]
#1702454
11/24/14 04:14 PM
11/24/14 04:14 PM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
What are you allowed to modify/change?
Basically, it's a "stock" motor and car...stock bore and stroke (within a certain spec)...stock, unmodified heads....stock pistons (or equivalent replacement)...stock, unmodified intake...stock carb...stock lift camshaft, any duration...headers, any converter, any gear and 30X9 max tire...
But, there's a LOT of "creative interpretation of the rules" going on...
If you can't handle the truth, you're living a lie.......
[Re: scatpacktom]
#1702459
11/25/14 12:01 PM
11/25/14 12:01 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
There was the .250 rule in effect for decades. Then a few years ago it disappeared. Now your can throat to a certain extent. Some heads benefit more than others from this.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: barracuda man]
#1702462
11/25/14 12:56 PM
11/25/14 12:56 PM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
Stock Class Racing requires one thing to be competitive deep pockets But NHRA has changed some stuff for 2015, the newer cars 2008 and up will have their own classes and that lets some of the older combos be a viable car again. Just check out class racerracer.com
Switched to the dark side...
[Re: sixpackbee]
#1702466
11/25/14 07:29 PM
11/25/14 07:29 PM
JSR1485
Seaford Delaware
I would love to run a Super Stock car, just don't have the coin to turn my 69 Dart into one.
[Re: classracer]
#1702467
11/25/14 07:54 PM
11/25/14 07:54 PM
Posts: 20,631 in a cattle trailer down by th...
Guitar Jones
There are a few stock eliminator racers on Moparts. Most like myself are just lurking around. To answer some....It can be expensive, it just depends on what you want to do and how much you want to spend.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: mr_340]
#1702469
11/26/14 01:00 AM
11/26/14 01:00 AM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
I would have liked to see the V10 head on the DP Challenger. I'd like to see what a 268cc intake port looks like.
Not sure whose, but they have someone's CNC port program in them, I could see that through the oil film in every intake port.
[Re: Big Squeeze]
#1702470
11/26/14 05:24 PM
11/26/14 05:24 PM
Posts: 170 renton , washington
perfmachst
renton , washington
hi, also, ring combo's are critical, wall finish, , valve seat angles, type of valves, crank indexing stroke equalized, port flows and velocity. all ports flow same. intake manifold casting, carb rework for flat fuel curve, suspension.
[Re: perfmachst]
#1702471
11/27/14 12:33 AM
11/27/14 12:33 AM
Posts: 133 Winter Park, Florida
classracer
If you don't have a bunch of this:
" also, ring combo's are critical, wall finish, , valve seat angles, type of valves, crank indexing stroke equalized, port flows and velocity. all ports flow same. intake manifold casting, carb rework for flat fuel curve, suspension." etc., etc., etc., etc.
The best set of "STOCK APPEARING" heads will not help.
[Re: classracer]
#1702472
11/27/14 12:44 AM
11/27/14 12:44 AM
sixpackbee
Western New York
Don't forget the 20 converters that are pumped through the car or the several different gear ratio sets in the 904. The suspensions in both my a bodies are pretty simple. Engine wise it is ring package and camshaft/valvetrain. Need to make these things rpm.
[Re: moparpollack]
#1702473
11/27/14 12:46 AM
11/27/14 12:46 AM
Posts: 5,894 Florida
Locomotion
They don't say if it has to sustain weight of a passenger do they?
Passenger seat has to match the driver's seat. I suppose you can swiss-cheese it under the upholstery, but I'd hate to do that if I already had lightweight seats in it.
