Page 1 of 3 1 2 3
Finally a BB automatic overdrive tranny! #1702043
11/22/14 10:37 PM
11/22/14 10:37 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
Anybody know about these? Anyone have any experience with them? Wonder how much?
http://tranztechtransmission.com/dubuque-ia-overdrive-transmissions.htm
Careful, your character's showing!
Re: Finally a BB automatic overdrive tranny! [Re: mopar346] #1702044
11/22/14 11:14 PM
11/22/14 11:14 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
If they can't quality check their add I'd be reluctant to give them a tranny. i,e, "GET THE OVERDRIVE CONVERSATION FOR YOUR TORQUEFLITE BIG-BLOCK!" Conversation, really?
Re: Finally a BB automatic overdrive tranny! [Re: Cudajon] #1702045
11/22/14 11:19 PM
11/22/14 11:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Add? really?
See, it can happen to anyone can't it?
Don't be the exception.
Re: Finally a BB automatic overdrive tranny! [Re: Cudajon] #1702046
11/22/14 11:25 PM
11/22/14 11:25 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Transvestites are people too, so they should neither be sold or given away.
Re: Finally a BB automatic overdrive tranny! [Re: Alaskan_TA] #1702047
11/22/14 11:37 PM
11/22/14 11:37 PM
BDW Online content
BDW  Online Content
Sounds like a 518 to me, maybe they just do the bell housing mod for you?
Re: Finally a BB automatic overdrive tranny! [Re: Cudajon] #1702048
11/22/14 11:40 PM
11/22/14 11:40 PM
mopar346 Offline OP
mopar346  Offline OP
Most people (shops anyway) hire people to run their websites, so I wouldn't exactly hold that against them. I was thinking more of just getting a case from them and having my builder build it.
Re: Finally a BB automatic overdrive tranny! [Re: Supercuda] #1702049
11/22/14 11:41 PM
11/22/14 11:41 PM
mopar346 Offline OP
mopar346  Offline OP
Add? really?
You cant write this stuff.
Re: Finally a BB automatic overdrive tranny! [Re: Alaskan_TA] #1702050
11/22/14 11:43 PM
11/22/14 11:43 PM
mopar346 Offline OP
mopar346  Offline OP
I'll have to take your word for that Barry, I know Alaska gets really cold but................
PA aiunt much better by the way.
Re: Finally a BB automatic overdrive tranny! [Re: BDW] #1702051
11/22/14 11:44 PM
11/22/14 11:44 PM
mopar346 Offline OP
mopar346  Offline OP
Yep, from what I understand they cut a 727 bell off and graft it to a 518 case. Thought about doing it locally but looking for input.
Re: Finally a BB automatic overdrive tranny! [Re: Alaskan_TA] #1702052
11/23/14 01:18 AM
11/23/14 01:18 AM
Nor be allowed on the streets to mix with and talk to kids or regular people, put them in with the rest of the crazys
Re: Finally a BB automatic overdrive tranny! [Re: Cab_Burge] #1702053
11/23/14 01:35 AM
11/23/14 01:35 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Cab...
...FAFO...
Re: Finally a BB automatic overdrive tranny! [Re: mopar346] #1702054
11/23/14 01:13 PM
11/23/14 01:13 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I hope that ain't what I think it is.
Sorry, had to continue with the trend.
- Stu Harmon
Re: Finally a BB automatic overdrive tranny! [Re: mopar346] #1702055
11/23/14 02:15 PM
11/23/14 02:15 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Ultrabell bellhousing.
It still doesn't solve the problem of the girth of the 518 interfering with the floorpan and torsion bar crossmember...
Re: Finally a BB automatic overdrive tranny! [Re: GY3] #1702056
11/23/14 04:29 PM
11/23/14 04:29 PM
Alberta
rustbuckett68 Offline
Alberta
"external overdrive' and 'only two feet longer'.
Re: Finally a BB automatic overdrive tranny! [Re: rustbuckett68] #1702057
11/23/14 06:29 PM
11/23/14 06:29 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Can you really get 25 to 30 percent better gas mileage?
I have mechanical Aptitude.
I can screw up anything.
Re: Finally a BB automatic overdrive tranny! [Re: GY3] #1702058
11/23/14 06:39 PM
11/23/14 06:39 PM
mopar346 Offline OP
mopar346  Offline OP
That's why I am looking for input, what started this is a picked up a Aug 08 collector's guide and it had an article on it that claimed a direct bolt in with no major modifications to the floor pan. They use a special tranny crossmember and shorten the drive shaft but don't talk about any mods to the floor or tortion bar mount. Seems like this would be popular knowledge at this point IF it were true but if no one here has any direct knowledge of it one would have to doubt the claims.
As for 25-30% increase in MPGs, a lock up will give you close to 10% I think so a .60-70 to one ratio would help and keep in mind 25% or 12 MPG is only 3 MPG. It would be basically like changing from a 3.91 gear to a 2.94 gear.
Re: Finally a BB automatic overdrive tranny! [Re: mopar346] #1702059
11/23/14 07:16 PM
11/23/14 07:16 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
As for 25-30% increase in MPGs, a lock up will give you close to 10% I think so a .60-70 to one ratio would help and keep in mind 25% or 12 MPG is only 3 MPG. It would be basically like changing from a 3.91 gear to a 2.94 gear."
I think your estimate on the gains with the lock up converter are optimistic. a 10% gain? I don't think even in the absolute best case scenario that you'd get more that 4-5% from the converter unless you go from a 5000 stall unit to the lock up type.
The RPM decrease percentage does not always directly translate to the equal gain in mileage.
Example: If you reduce cruising rpms by 25%, it does not mean the mileage will increase by 25%.
I had a Gear Vendors overdrive in my car for about 2 years. I ran a 3.91 gear through the .78 OD. The final drive in OD was 3.05. The best mileage I ever got was 12.81 and I was happy to get that.
I made the same trip a year before with no OD but with a 3.23 diff. I got 11.3 on one tank, 10.8 on another and just figured an 11 mpg average. The comparisons may have been skewed a bit since I drove real easy with the GV to see what the gains would be with the overdrive.
Re: Finally a BB automatic overdrive tranny! [Re: mopar346] #1702060
11/23/14 08:20 PM
11/23/14 08:20 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
Mopar346..
I put an A518 non-lock up into a customers car (1972 Plymouth Duster) and the customer was very happy with the results. I didn't have to cut any holes in the floors, I just had to make some hemispherical indents in the floor/tunnel area for clearance. I had to cut out the center of the torsin bar crossmember and I replaced the support with an 1/8" piece of plate steel formed to shape and had to make my own crossmember. It worked so well that I am going to install an A518 lock up style into my 1971 Charger with a 383 engine.
Re: Finally a BB automatic overdrive tranny! [Re: GLR] #1702061
11/23/14 08:36 PM
11/23/14 08:36 PM
mopar346 Offline OP
mopar346  Offline OP
If the tortion bar mount has to be modified then it's a no go for me. Oh well, just hoping that's all.
Thanks for the info.
Frankenduster,
And yea, 10 might be a little hopeful on an increase from a lock up. I wonder what improvement you would have seen if you stayed with the 3.23s?
Re: Finally a BB automatic overdrive tranny! [Re: mopar346] #1702062
11/23/14 09:01 PM
11/23/14 09:01 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
Well, I had to cut the top center out of the torsin bar frame member because of the size of the overdrive section being so large. I don't know if you would have to do that on a B or E-body car for sure... but I would guess you would have to.
Page 1 of 3 1 2 3
