Re: Do you run tubes in your slicks?
[Re: bobs69]
#1701578
11/22/14 12:02 AM
11/22/14 12:02 AM
Posts: 43,163 Bend,OR USA
Cab_Burge
I bougt a set of M/T 14x32x15 stiff side walls last year from Summit is Sparks, NV on the way to the MATS race in Las Vegas this year in April. My car had a set of Goodyear 16x33x15 that had been on the car for over 6 years before I bought it and I could see the cords on the sidewalls breaking on the sides at the max section width, they where ran tubeless on the 15 inch wide rims with a bunch of rim screws and had a bunch of rubber left on them according to the wear dots I ran them at the big Spring Fling 4 day bracket race the weekend before the MATS race. I had the local Goodyear race tire warehouse mount my new M/T after that race, I tried to buy tubes from them and they told me that they hadn't sold or had race inner tubes or inner liners in over 5 yrs My M/T where no slower or faster than them old Goodyears No tubes in them yet, no soap either yet Probally take them off the rims this winter and soap them rascals up and try again IHTHs My car weighs 2750 with me in it, best 60 ft. so far has been 1.27 off the trans brake
[Re: Monte_Smith]
#1701579
11/22/14 12:13 AM
11/22/14 12:13 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I've been racing since the 60's and never ran over a screw or nail, I even drove for a few years with slicks on the street. Must be lucky. Back to the tubes. Usually I start out without tubes, soap up the insides real good but when the side walls start leaking it's time to put in the tubes. I just have a low 10 bracket car so it really doesn't matter if I do lose a couple .000 One thing I have found is the proper install of the tubes. If you have ran the slicks soaped up you need to totally get all the soap residue from inside the tire. Buy tire talc or baby powder and cover the tube and inside of the tire to keep the tube from sticking, if it sticks it rips.
[Re: JERICOGTX]
#1701585
11/22/14 01:10 PM
11/22/14 01:10 PM
Posts: 685 SW Ohio
AAR-B4
SW Ohio
Tubes help stiffen the sidewall.......which is never a bad idea, plus they don't leak
Monte
This
"This" is a confusing statement. The soft flexible sidewall of the slick is designed to absorb the hit at the starting line and prevent spin. Enlighten me......
I have not run tubes for decades, for reasons: 1. Expense (I'm cheap) 2. Increase weight 3. If you have a puncture at the track just plug the tubeless. If you have tubes you are likely headed home.
[Re: bobs69]
#1701587
11/22/14 03:46 PM
11/22/14 03:46 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Phoenix tires with tubes.We have always used tubes.Tire sidewalls also last longer using them.
[Re: AAR-B4]
#1701588
11/22/14 05:08 PM
11/22/14 05:08 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Monte
This
You will beat the sidewall out of a slick well before you wear the tread out in most cases. The tube helps stiffen the sidewall, which will keep you from "crushing" the tire at the hit, which is what kills the sidewalls.
And even though guys do it ALL the time........NO tire maker suggests that you put a plug in a slick. I know I never would
Monte
[Re: Monte_Smith]
#1701589
11/22/14 05:19 PM
11/22/14 05:19 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
I always run tubes in my M/T drag slicks but in my street drag radials I run tubeless. My stick car seems to hook better with tubes Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
