It's also the cone type Sure Grip. Test to see if it's working. Then, IF you take the differential out, take the SG unit to a machine shop with a copy of instructions on how to "rebuild" it. Wouldn't hurt to take a few thousandths off the small ends of the cones.
JohnRR, RickE, and a host of others are going to step in right now to tell you that differential is a POS. Well, it is, but it'll work for a while at least and you already have it. And the "rebuild" is really just a crutch to get it to work again for a while. But if done properly it should last for years, especially on a car that is not a daily driver.
Other notes: 3.55 or 3.23 gearsets can be found under most every Ramcharger or pickup, IIRC. Also NOS gearsets shouldn't cost an arm and a leg.
R.
