Anybody make a Magnum throttle cable bracket? #1701137
11/20/14 01:50 PM
11/20/14 01:50 PM
Goodyear Arizona
midnite360 Offline OP
Goodyear Arizona
Is there a throttle cable bracket for magnum engines floating around that allows the use of the stock kickdown linkage? The only one around I can find is for use with a Lokar Cable and I would like to use the stock kickdown linkage since I already have a bunch of them.... This is for a 77 Warlock.
Re: Anybody make a Magnum throttle cable bracket? [Re: midnite360] #1701138
11/20/14 02:22 PM
11/20/14 02:22 PM
Andrewh Online content
Andrewh  Online Content
but it isn't just the bracket. everything is on the wrong side.
you would have to modify the lever arm too to reach over, or find a way to swap the tps.
it was far easier to steal the parts off a mag transmission and use the stock kick down cable from that van, then try to modify it to use the original kick down.
