Re: engine swap or head change?????????
[Re: HotRodDave]
#1700932
11/19/14 09:10 PM
11/19/14 09:10 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Sell the 4.7 heads and the short block, buy a 5.7, motor mounts are the same, bellhousing is the same and the confuser will work, you will need a wire harness from a same year 5.7 and you will have a much nicer truck for a little extra investment
Lol Working on that with the other one. But I still need a truck to go back and forth to work. Mounts the same? I haven't heard that. My 03 has the NGC so wiring is really simple. Is it easier and faster to swap engine than just the heads? Matt
[Re: MattW]
#1700933
11/19/14 11:30 PM
11/19/14 11:30 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Yes motor mounts are the same.
It is probably easier to swap heads but you still have a piece of stink 4.7 when your done.
[Re: HotRodDave]
#1700935
11/20/14 12:52 PM
11/20/14 12:52 PM
MattW
Ontario Canada
Really. I hope your right. So you think it would be easier to change the heads.
