Strange or Aerospace Rear Dual Caliper Brakes?
#1700892
11/19/14 05:36 PM
11/19/14 05:36 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I'm thinking about/planning to replace my stock 11" Drums with a dual caliper disc brake system. I've narrowed my options to Strange and Aerospace and wanted to solicit some feedback/opinions on these kits from you guys. (I'm going with Dual caliper setup since I footbrake and also like to put most my braking to the rear when on the brakes at the finish line, rather than locking up the front runners) Does anyone have any experience both of these kits and have opinions on which one is better or what you like about one vs the other? Strange Rear Dual Capiler 2 piece rotor - $1,120 http://www.strangeengineering.net/dual-brake-kit-65-73-mopar-2-pc-rotor-soft-pads.htmlAerospace Rear Dual caliper 2 piece rotor Heavy Duty Brake Kit Dana/ Mopar Housing Ends 5/8 Studs Nickle Plated Rotors - $999 http://shop.aerospacecomponents.com/reardragracebrakekitoldspontiachousingends-1-4-1-1-1-3-1.aspx
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Strange or Aerospace Rear Dual Caliper Brakes?
[Re: Big Squeeze]
#1700896
11/19/14 07:25 PM
11/19/14 07:25 PM
WadeMetzinger
Tulsa, Ok
Putting most of your braking to the rear is a BAD idea...You ALWAYS want the front tires to lock up before the rears!!! When the fronts lock, you go straight...when the rears lock, you go sideways....
That's typically the theory but when running on 4" front runners, it doesn't take anything to lock them up (and when they lock up you don't go straight) and since I'm bracket racing I'm on the brakes pretty hard at the top end. So I adjust most of the braking to the rear and the car squats and pulls down better with the big slicks. (now if they locked up, it may make you go sideways but it take a lot to lock up a 14" slick)
So you have a very valid point in most scenarios but in my case, bracket racing with skinny's up front and 14" slicks out back, rear braking works better.
[Re: WadeMetzinger]
#1700897
11/19/14 09:32 PM
11/19/14 09:32 PM
Posts: 11,542 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
$100 difference? Strange, all day long. Depending on what's on the car, a master cylinder change may also be needed.
A single caliper set up will be plenty of brake for stopping. A dual system is useful if you footbrake and want to get up hard on the converter.
[Re: WadeMetzinger]
#1700900
11/20/14 08:06 AM
11/20/14 08:06 AM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
Strange . If you need a quote let me know, I dropship their stuff all the time. Mike
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: Project kickin A]
#1700901
11/20/14 09:40 AM
11/20/14 09:40 AM
Posts: 503 Idaho
1320Dart
Idaho
Most all the race cars that I've had the pleasure of helping work on, has had Aerospace all around. My car has Strange on it. but that's what was on it when I bought it. My car also has an adjustable proportioning valve in between the front and rear brakes too
Greg ----------------------------------------------------------------- Cost is irrelevant, making memories is far more valuable!
[Re: Monte_Smith]
#1700902
11/20/14 04:24 PM
11/20/14 04:24 PM
Posts: 562 Ohio
lockjaw-express
Ohio
Hi Wade, I am looking at the Aerospace rear brakes that you set the link to, however they are vented rotors, and the Strange are single plate race rotors. I really like the Strange rear brake setup better, but my '69 GTX is used on both Street and Strip...how would the Strange hold up to street driving? My car is not a cruiser, but would be more of a limited use street car, but also used at the strip. Thanks, Mark
[Re: lockjaw-express]
#1700903
11/20/14 04:52 PM
11/20/14 04:52 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
I beleive what you think is going to happen and what will happen with dual rear calipers is totally different. I have driven several turbo cars including my own back years ago before bump boxes with dual calipers and it will lock up the rear tires in the blink of an eye. You cannot jam them hard much less turn up the prop valve where the rears are really aggressive. I think you are asking for trouble.
One day I will have something cool here.
[Re: WadeMetzinger]
#1700904
11/21/14 05:10 PM
11/21/14 05:10 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
I couldn't say what one is better but I do know that Aerospace Components are running a 25% off special on there website. AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: sdaurity]
#1700905
11/21/14 05:43 PM
11/21/14 05:43 PM
Posts: 503 Idaho
1320Dart
Idaho
The way mine is setup is, the proportioning valve is used to make the rears less aggressive. FWIW
[Re: turbobitt]
#1700906
11/21/14 05:48 PM
11/21/14 05:48 PM
Posts: 562 Ohio
lockjaw-express
Ohio
The Strange would be lighter in rotating weight, may not take the heat of street driving, but the Aerospace is vented, heavier, and would take street use for sure.
If the single disc strange would be fine for street driving, then I would go for those. I know they would hold better, maybe?
I do have light-weight Wilwood vented rotors in the front, but like Wade, I have narrow front runners.
I would appreiciate any suggestions, and also per my note above in this thread.
BR, Mark
#1700907
11/21/14 06:58 PM
11/21/14 06:58 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
BR, Mark
As long as you mentioned Wilwood I made a rear axle bracket that held 2 calipers and I use a hydraulic hand brake for the E brake on the extra rear caliper.
#1700910
11/22/14 10:56 AM
11/22/14 10:56 AM
WadeMetzinger
Tulsa, Ok
Hi Wade, that is why I was looking at the Aerospace rear brakes that are vented and advertised as pro-street, and are NHRA approved.
Do you think I would need the dual caliper unit you have a link to hold 700 HP on launch? Or would a single hold it?
Thanks, Mark
This is the general thought on dual calipers but I know a lot of cars doing just fine with single caliper with that much or more HP. It really depends more on how loose your converter is and how high you want to stall it on the line.
