Re: 1985 Ramcharger miss
[Re: Racer33]
#1700819
11/19/14 02:18 PM
11/19/14 02:18 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
They're VERY lean, tended to burn exhaust valves. 120 hp doesn't move two tons very well.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#1700820
11/19/14 02:42 PM
11/19/14 02:42 PM
Posts: 179 Norfolk, NE
Racer33
Norfolk, NE
33's and a 3.21 gear doesn't help much either.
[Re: Racer33]
#1700825
11/19/14 07:46 PM
11/19/14 07:46 PM
RapidRobert
Here's mine & we're pretty close . 318/2wd/3.23 (3.21?) sure grip. 10-12 MPG, starts/runs good. Bad: gas gauge non op/rad leak/oil leaks. You have a timing (total/curve) issue but that ain't what is causing the hesitation. #1 check AP squirt/duration, should be immediate on tip in. Nor is the carb lean but you might have a vac leak. Check into the std tune up items incl rotor phasing. You wouldn't happen to have a wiring diagram would you , i wanna get after that gas gage prob.
[Re: Racer33]
#1700828
11/19/14 11:18 PM
11/19/14 11:18 PM
RapidRobert
yes I am hoping to race again next April. you might check rotor phasing/reluctor gap both of which are changed by the amt of vac adv which is changed somewhat by throttle position. Cap the can & retry it & it'd be real easy to do. Either of the two might be borderline & getting pushed just over the edge. Holler how it turns out & what it ends up being & it may very well be lean. A guy sent some of the gas gauge wiring but there were at least 2 pairs of wires there & I couldn't make sense of it all without additional schematics to go along with it. EDIT Mine is all original & if it ain't lean I would assume yours ain't (jetted) lean either
[Re: Racer33]
#1700830
11/20/14 02:56 PM
11/20/14 02:56 PM
RapidRobert
Success! yeah I saw that once & it was from not setting the cap straight down. Good possibility your diagrams would help even tho they are a year or so later. There is a vacuum valve on one of the heater hoses between firewall and eng. Mine was leaking so I just replaced it with a regular on/off shutoff valve with a hose barb on each end & I open it in cold weather & shut it in warm/hot weather so the AC will be right when I need it. Works perfect! I do wanna trade the truck for a 63-66 2dr A body daily driver with good floors/sheetmetal/glass & drivetrain can need work. A guy I built an eng for bought it from the original owner & when my 65 dart was Tboned he sold it to me so I would have something to drive. it is all oiginal (ex for that valve & tune up items/fuel pump & has never been hit. Holler when you can
