Gen 3 Hemi timing chain? #1699625
11/16/14 12:55 PM
11/16/14 12:55 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I was reading this article about the timing chain recall
http://www.hotrod.com/news/chrysler-hemi-timing-chain-defect/
Was wondering what you guys are using for a timing chain?
I know Manley sells a double roller 73205 and 73206
Are there any others?
Thanks!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Gen 3 Hemi timing chain? [Re: RylisPro] #1699626
11/16/14 01:07 PM
11/16/14 01:07 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Manley
If you like drag racing, support your local track.
Re: Gen 3 Hemi timing chain? [Re: CHAPPER] #1699627
11/16/14 01:19 PM
11/16/14 01:19 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
That doesn't affect the generation of hemis that most people use for the classic builds. 2009+ is the eagle 5.7.
I'm using a 6.1 timing set from mopar. That's all I would use in terms of factory parts. I don't know anything about the Manley parts.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Gen 3 Hemi timing chain? [Re: AlexP] #1699628
11/16/14 01:40 PM
11/16/14 01:40 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Here is a pic of the stock chain on the left vs. Manley on the right
The Manley looks beefier but is it really stronger?
Stock chain is for stock applications but how is it for sustained high rpm use?
Road racing for example?
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Gen 3 Hemi timing chain? [Re: RylisPro] #1699629
11/16/14 01:43 PM
11/16/14 01:43 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Wade ran a stock unopened 6.1 at several track events and the big bend open road race. No issues at all.
The factory stuff is tougher than people give credit.
The only non factory parts in my shorrtblock are the cam and valve springs.
Re: Gen 3 Hemi timing chain? [Re: CHAPPER] #1699630
11/16/14 02:13 PM
11/16/14 02:13 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
Only draw back to the Manley chain is I had to grind the timing cover a good bit to make it fit
Re: Gen 3 Hemi timing chain? [Re: biff426] #1699631
11/16/14 02:39 PM
11/16/14 02:39 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
It looks like there are other double roller timing chain sets out there
Lunati 95505
http://www.jegs.com/i/Lunati/638/95505/1...BQ1QaAhMs8P8HAQ
Jegs 555-20480
http://www.jegs.com/webapp/wcs/stores/se...p;storeId=10001
Howards 94332
http://www.summitracing.com/parts/hrs-94332/overview/make/dodge
Comp Cams 7114
http://www.jegs.com/i/Comp-Cams/249/7114/10002/-1
Looks like a generic set that all the aftermarket companies sell. The keyway says "Made in USA" but I'm betting everything else is chinese.
So I guess it's what kind of take out you prefer
Mexican or Chinese
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Gen 3 Hemi timing chain? [Re: RylisPro] #1699632
11/16/14 02:45 PM
11/16/14 02:45 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Funny that you mention it.
A lot of the Hemi Stuff is made in Mexico.
Re: Gen 3 Hemi timing chain? [Re: AlexP] #1699633
11/16/14 02:50 PM
11/16/14 02:50 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I thought all the Hemi stuff is Hecho en Mexico?
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Gen 3 Hemi timing chain? [Re: RylisPro] #1699634
11/16/14 03:10 PM
11/16/14 03:10 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Most, but not all. It's all between USA, Germany and Mexico to the best of my knowledge.
Re: Gen 3 Hemi timing chain? [Re: AlexP] #1699635
11/16/14 03:17 PM
11/16/14 03:17 PM
MN
hemidup Offline
hemidup  Offline
MN
From what I've seen is that the tensioner slides or the tensioner plate will break before the chain will.
Re: Gen 3 Hemi timing chain? [Re: hemidup] #1699636
11/16/14 03:19 PM
11/16/14 03:19 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I've seen the same. Mostly on 5.7 backing plates. One of our 392's for a shop car had a broken tensioner plate and the nylon portion just fell into the oil pan. That was so incredibly lucky.
BTW Jerry...I called the shop the other day to ask you a question and the guys told me you retired?
Re: Gen 3 Hemi timing chain? [Re: hemidup] #1699637
11/16/14 03:20 PM
11/16/14 03:20 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
It's not which one is stronger, but which one lasts longer and keeps the camtiming correct.
Re: Gen 3 Hemi timing chain? [Re: AlexP] #1699638
11/16/14 03:45 PM
11/16/14 03:45 PM
MN
hemidup Offline
hemidup  Offline
MN
It was just time to move on. Currently in the process of relocating into a new shop. My shop this time.
Jerry Williams.
Re: Gen 3 Hemi timing chain? [Re: hemidup] #1699639
11/16/14 04:16 PM
11/16/14 04:16 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I would use stock or Crower. I just put a brand new $91 Mopar set in my build.
Mopar to the bone!!!
Re: Gen 3 Hemi timing chain? [Re: RylisPro] #1699640
11/16/14 05:02 PM
11/16/14 05:02 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
I paid $169 shipped for the Comp 7114 from Amazon. It's still on there for that price. Summit and Jegs description says it has a Torrington bearing, but mine doesn't. Comp's site was giving me fits just now when I was trying to search and read their description.
Re: Gen 3 Hemi timing chain? [Re: Charger453] #1699641
11/16/14 07:56 PM
11/16/14 07:56 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
What chain do the Drag Paks run?
Re: Gen 3 Hemi timing chain? [Re: Moparmal] #1699642
11/16/14 08:31 PM
11/16/14 08:31 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
It appears the Drag Paks run the stock 6.1 chain 05037579AB.
http://www.arrowracingengines.com/2011hemidragpak.html
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Gen 3 Hemi timing chain? [Re: RylisPro] #1699643
11/16/14 08:38 PM
11/16/14 08:38 PM
Moparmal Offline
Moparmal  Offline
I guess we can assume the drag pak project engineers did their homework?
Re: Gen 3 Hemi timing chain? [Re: Moparmal] #1699644
11/16/14 08:50 PM
11/16/14 08:50 PM
MD-USA
Dodgeguy101 Online content
Dodgeguy101  Online Content
MD-USA
Is there a difference in the engines between the cars and pickups? I have a 2011 ram with the 5.7 with MDS, no mention of recall for the these engines? I assume there is a difference in parts or no one has cried enough on these engines yet.
