Re: Gen 3 Hemi timing chain?
[Re: AlexP]
#1699628
11/16/14 01:40 PM
11/16/14 01:40 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Here is a pic of the stock chain on the left vs. Manley on the right The Manley looks beefier but is it really stronger? Stock chain is for stock applications but how is it for sustained high rpm use? Road racing for example?
[Re: RylisPro]
#1699634
11/16/14 03:10 PM
11/16/14 03:10 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
I thought all the Hemi stuff is Hecho en Mexico?
Most, but not all. It's all between USA, Germany and Mexico to the best of my knowledge.
[Re: AlexP]
#1699635
11/16/14 03:17 PM
11/16/14 03:17 PM
Posts: 833 MN
hemidup
MN
From what I've seen is that the tensioner slides or the tensioner plate will break before the chain will.
[Re: hemidup]
#1699636
11/16/14 03:19 PM
11/16/14 03:19 PM
AlexP
Houston, Tx
I've seen the same. Mostly on 5.7 backing plates. One of our 392's for a shop car had a broken tensioner plate and the nylon portion just fell into the oil pan. That was so incredibly lucky.
BTW Jerry...I called the shop the other day to ask you a question and the guys told me you retired?
[Re: hemidup]
#1699639
11/16/14 04:16 PM
11/16/14 04:16 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I would use stock or Crower. I just put a brand new $91 Mopar set in my build.
Mopar to the bone!!!
